OBD1 crank sensor with OBD2 wiring
  • Bennetts22@aol.com
    • Jun 2006
    • 171
    I am asking this for a friend. He has a Euro 328 engine that hes trying to install in a 98 Z3 Both are 2.8L but the Euro engine uses the front crank sensor not the one in the rear of the block like the US engines have.
    Both sensors use 3 wires but are different colors. can the obd1 sensor work with the obd2 wiring? and does anyone know the color wires that need to go together?
    thanks brandon
  • BeirBrennerE30
    • 2740
    nope... sensors are not compatable. The wiring and computer needs to be the same as the sensor. This is how it works for the us engines at least.
    e30sport.net
    '06 M3 Competition - 6-speed
    '97 Range Rover Vitesse
      • Jun 2006
      • 171
      so is there anyway way to run a front sensor with 0bd2
        • Jun 2006
        • 171
        The big problem is that the engine was sold to a BMW dealer to be installed in a US Z3 with a bad engine. The engine is already installed but the problem is the sensor. Either I figure a way to make it run or I have to pay to have them remove this engine.. TIA
        Brandon
        • lateapex31
          • 79
          How is it your problem that the dealership doesn't know how to install this engine?
          • BeirBrennerE30
            • 2740
            you cant mix obd1 and obd2 sensors on the same car... the computer wont know what the hell is going on...
            e30sport.net
            • FredK
              • 14752
              The sensor that is mounted at the front of the engine is a European M52 specific crank position sensor. It is not used with the M50 or M50TU.
              Both the European M52 and the US M52 use a Siemens MS41.x DME.
              I assume the replacement engine is a Euro aluminum block engine? If so, it probably doesn't have the hole at the rear of the block for the rear mounted crank position sensor, right?
              I am sorry I can't be any more help, I don't have the European ETM.
                • Jun 2006
                • 171
                the engine has no hole in the block.. both sensors are 3 wire. even if the sensors were wired right the car still wont run?
                  • Jun 2006
                  • 171
                  they want 1500 from me for selling them a engine they cant use for taking the engine back out
                    • Jun 2006
                    • 171
                    50 bucks to the guy who figures this out
                    • FredK
                      • 14752
                      I finally found the Euro ETM in my collection of files. Here are the two images that pertain to this discussion.
                      Of course, if the number of teeth on the crank differ from the rear mounted tone wheel, then it won't work.
                      MS41.0 (Euro M52)
                      MS41.1 (US M52)
                      Pic of US tone wheel (taken from bimmerforums, user dmb882)
                      Now, I am not sure how to read the above diagram for the Hall Sensor, because there is no indication of what is Vss, Ground, and Signal. Anyone care to comment?
                      My guess is the ground color won't change -- BR to BR
                      If you do it by DME pin to DME pin (48 to 48, 83 to 83) it is:
                      Z3 harness to Euro M52 CKPS, guess #1
                      Yellow to Red/Yellow
                      Black to Yellow
                      I'd check the resistances between pins just to see if the abovementioned suggestions are reasonable.
                        • Jun 2006
                        • 171
                        MS41.0 (Euro M52)
                        MS41.1 (US M52)
                        Black to Yellow
                        thanks for the help fred. i will see whats up with the wires in the morning
