Trailing arm reinforcements
  • grib
    • Oct 2006
    • 151
    One of the members of our local board just had reinforcements fabricated (among other things) onto his RTA's. I have Z3 RTA's that I plan to install as part of my 5-lug swap. I'm curious if anyone else has done/considered this in conjunction with a higher-output swap.
    I ask because it seems like this is one of the key design changes that BMW made when putting the S52 into the ZM chassis (which has a suspension setup very similar to the e30). The reinforcements basically consist of a triangular plate connecting the hub/knuckle carrier to the main arm and then a cross bar which turns the V arm into an A arm.
    1987 325i Cabrio - SOLD
    2014 Chevy Volt
    2007 FJ Cruiser
  • 1990m3
    • 1180
    funny you mention it. Since my swapped car is turning into my track car I just removed the entire rear suspension last weekend so I can begin to beef it up a little bit. Swaybar reinforcements along with toe/camber adjustments too. I also plan on a similar M couple style a-arm reinforcement for good measure. Whether or not its necessary is not the point for me, I'm trying to make this a relatively trouble free track car (if that's possible).
    • Mike B.
      • Jan 2006
      • 987
      I've done the re-inforcements just for good measure.
      I didn't use weld-in camber/toe adjusters though. I just picked up some shortened, aluminum subframe bushings to effectively raise the subframe. They are cut-down by 12mm, and you need 12mm spacers for the diff and subframe brackets.
      This helped dial out a good portion of the camber/toe issues you get when you lower a car.
      • cheades
        • 632
        Mike B - can you give us mroe info on this, where you got them from, etc.
        • gobuffs
          • Dec 2004
          • 513
          I put on the M coupe trailing arms on my car to get larger halfshafts and vented brakes on the rear for the Euro swap.
          • Mike B.
            • Jan 2006
            • 987
            I picked mine up from Muzzi Motorsport, but I am working with AKG Motorsport to get some made here in the States.
            Here is a picture (very fuzzy) of one installed. Notice the spacer at the bottom. 12mm doesn't seem like much, but it significantly helps the camber/toe. My car is on coil-overs and I gained around 1.75 to 2 degrees of camber back based on rough measurements. This improved handling significantly.
            • 1990m3
              • 1180
              Mike B. - do you need a modified bushing that will allow the subframe to sit up higher?
              • Mike B.
                • Jan 2006
                • 987
                Yep, the modified bushing is 12mm shorter, hence the need for spacers to properly locate the diff and bolt up to the subframe brackets.
                It is similar in principle to roll-center spacers on E30M3 front struts (which I also installed).
                • Jason89i
                  • Sep 2004
                  • 875
                  NICE! ive also heard (never tried) installing the bushing upside down.
                  what did you do with the diff mounting? slotted or offset bushing?
                  cheers, jason
                  • Mike B.
                    • Jan 2006
                    • 987
                    Since the bushing is 12mm shorter than the stock bushing, you can use 12mm spacers for the diff bolts and the subframe brackets.
                    I found some M12 nuts from McMaster-Carr (12mm thick) and drilled out the centers to use as spacers.
                    I suppose a slotted or off-set diff bushing would work as well. You would still need the spacers for the subframe brackets.
                    Since I already had 2-pc poly bushings installed, I was just able to lower the whole subframe as a unit on a jack and pop the new aluminum ones in place. Compared to the task of replacing stock subframe and trailing arm bushing, it was really quite easy.
                    • cheades
                      • 632
                      What were the roll center spacers for the front struts, do you have any pictures of those?
                      • FredK
                        • 14752
                        • Mike B.
                          • Jan 2006
                          • 987
                          Yep, those are the ones. I should mention that I am running E30M3 suspension componants. The roll center spacers won't work with the 4-lug struts.
                          • Tom944
                            • Dec 2005
                            • 150
                            I've got the same subframe bushings from Muzzi as Mike B. Very nice quality and they give a good correction of the camber in the rear.
                            Diff bushing for stressfree mounting :
                            E30 Euro-S50B30 Tracktoy
                            E30 M20B25 Drifttoy
                            • Farbin Kaiber
                              Lil' Puppet
                              • 29502
                              I have a feeling I want to see more of your car ^^^^^^^^^^^^^^^^^^
