89+ radiator from an Auto. ?
  • 87-325ic
    • Apr 2006
    • 1198
    can anyone confirm if the radiator from an automatic e30 will work with the swap?
    s50 going into an eta.
    any chance of blocking the auto tranny ports or will it just not fit in there?
    thanks.
  • 87-325ic
    • Apr 2006
    • 1198
    bump,, please help me a little.
    i did a search and found some people saying that an auto radiator "will" work,
    but can anyone confirm this for me, what will i have to do differently than with the manual rad?
    • FredK
      • 14762
      It's essentially the same radiator. You just need to block off the ports where the transmission lines bolt in. But you don't really need to block those ports off.
      Please avoid bumping a topic more than once in a 24h period. Otherwise you will be subject to a little something we call "street justice." jk :mrgreen:
      • 87-325ic
        • Apr 2006
        • 1198
        sorry, i thought it had been longer.. i have one in line to buy and was kinda rushed.
        thanks for your help. ill go with the one that i have found.
        cooling system is in the works finally. swap is 1/2 a step closer.
