Trans removal engine support
    I'm going to have to pull my trans out tomorrow. The Bentley shows that nifty brace to support the back of the block. I obviously dont have one. Also, the E34 oil pan has those "ribs" along the back. I'm afraid to break one if I use a wood block on a jackstand to shore up the engine.
    When you guys yank the gearbox out, what do you do about the engine?
    Thanks
    I had great success with a small piece of plywood under the oil pan and then a 2x4 on the head of my jack up against the plywood. It held like that for about a week. It was a smaller motor (s14) but the same principal either way. It works, if you use the oiplan to support just make sure to distribute the weight.
      I'm good with wood.
        Just like in the Bentley... Nice work!
          I had mine (M52) with the E34 sump on wood. But it tipped forward if you unbolted the box I guess thats the ally block!
          So I supported the sump from the front. For a while I also just had a short bit of wood between the front of the head and hte crossbar, near the bonnet mounts (make sure the Rad is out!)
          I Had the motor in without the box for about a week. No probs. Just pick your support point with a littel foresight!
          Nice woodwork by the way!
            well done, I like that idea!
              a jack stand would have worked fine.
              NEED SOME VINYL STICKERS???
