CEL wiring
  • 0000000000
    • 473
    CEL wiring
    I have a 1986 325ES with a M50NV also a gauge cluster that has a CEL. I need to know how to wire my CEL. From my DME to a wire in the cluster?
    I have no idea where to start. I know i have to run the pin out from the dme to my cluster cause the 86 doesnt have wiring for a CEL. But i have a cluster with a CEL.
    ???? Help ???
  • 0000000000
    • 473
    Anyone?
    • 0000000000
      • 473
      Help me get a CEL light.
      • ZiMMie
        • Jun 2004
        • 968
        start by reading the ETM for the Cluster.
        www.stancefactory.com
        • 0000000000
          • 473
          What is the ETM?
          • James Crivellone
            Head Janitor
            • 6301
            I've done tons of these, but I of course don't remember the exact pin.
            Locate the CEL wire on the C101 adaption that you have done, locate 12V and toss a lightbulb in the middle of it.
            The ECU will ground out to complete the circuit when it comes on.
            • 0000000000
              • 473
              I know that what has to be done. I just need to know what color wire it is on the gauge cluster side?
              naybe i dont know im lost
              • James Crivellone
                Head Janitor
                • 6301
                The e30 cluster does not have a built in CEL light, it has a removable light/plug (identical to the light in your center console ashtray for instance, that plugs into that back)
                Its 2 wires.
                • Jason89i
                  • Sep 2004
                  • 875
                  dont want to sound like a jerk, but i answered via pm's months ago.......twice.
                  Originally posted by jason89i
                  ...............the 86es does not have a check engine light orriginally, so there is no wiring for it.
                  if you have any other questions, feel free to drop me a line.
                  cheers, jason .
                  there is wiring for it at the m50 x20 connector...... but NOT at the c101 e30 side for an 86es.
                  Its 2 wires.
                  agreed. good advice james. just add a CEL in the cluster and wire if you really need one.
                  • 0000000000
                    • 473
                    Im so confused. You not being a jerk you just trying to tell me something i didnt understand.
                    This is my understanding to this. Behind the CEL in the gauge cluster there is 2 wires take one of the wires and hook it up to the pinout on the M50 side.
                    What do i do with the other wire. Or what do i do with both wires on the light side in the general.
                    • EtaSport
                      • 2853
                      Its pin 8 (gray wire) on them50 x20. Find a 12 volt switched power source, wire it to a light either in the cluster, or where ever you want it. wire the negative side of the light to pin 8 of the x20. your done.
                      Old and improved:
                      • 0000000000
                        • 473
                        YEAH, Sweet thanks.
