Cluster in 318 for M50 swap??
  • e30this
    • 3580
    What cluster did everyone use in there 318's when you did the M50 swap?
    I would guess one from a 325?
    moto or vdo?
  • ZiMMie
    • Jun 2004
    • 968
    U dont need a new cluster.
    Just a coding Plug.
    www.stancefactory.com
    • e30this
      • 3580
      I just found it in another thread
      Thanks for the reply :)
      • ultegra
        • Sep 2005
        • 20
        In the same vein, what coding plug would I need to use if I were to use an e30 m3 cluster coupled to an s50? I am considering this cluster because it has a higher red line on the tacho. Thanks all.
        • matt
          • 3732
          There is no coding plug that makes the M3 cluster read properly.
          • ultegra
            • Sep 2005
            • 20
            Can I take it, then, that I could use, say, an e30 325i coding plug in the e30 m3 cluster and then rig a resistive divider to cause the needle to deflect a lesser amount and consequently indicate the correct RPM? I am working on the principle that the tacho is simply a volt meter - I read this in another post - perhaps on here.
            • ultegra
              • Sep 2005
              • 20
              Stand Easy! Its here. (post of 12-22-2004, 04:20 PM - half way down the thread)
              I need to get one of these.
              • zookie
                • Mar 2008
                • 28
                Hey, I'm new here, sorry if this is uber-noob post, but anyone know if there is a way to get the mpg sender correct after a swap? Everyone wants to know what kind of mpg I'm getting with my m50, and with no mpg gauge or odo ( :-P ) I have no idea.
                • ///mza
                  • 47
                  Personally I find that the mpg gauge is just a flickering annoyance. It says i'm getting 40 miles per gallon when on average i'm getting around 15. Your best bet would be to use the OBC function because it reads from the fuel pump (if i'm not mistaken).
                  • matt
                    • 3732
                    You're mistaken. They both read from the same data.
                    The fuel pump has nothing to do with gas mileage...
