Parts cost E30 M42 to M50 swap?
  • josephb983
    • Nov 2007
    • 60
    Ok, I'm wondering what it might cost to put in an M50 in a 318is. What parts can be reused? What parts would have to be upgraded/replaced?
    So far, it looks like I'd need:
    M50 engine
    engine mounts
    wiring harness
    computer/ecu
    brake booster
    lower ratio differential
    M50 exhaust header
    Possibly:
    bigger radiator
    clutch/flywheel
    E36 driveshaft
    What else do I have to change/upgrade?
    What would the total parts cost come to, when I get done with all the required upgrades? My budget is limited, if it can't be done very cheap I may just do an E36 M42 swap, as with that engine everything should transfer directly I believe.
    Thanks.
  • FredK
    • 14762
    If you retain your transmission and radiator, you can save a little money. If you went all used on all of the parts and got an engine from a 525i, you might be able to squeeze the swap out for like $900. But, you'd probably want to replace stuff like the waterpump and thermostat housing. I know it could be done for cheaper, but the market varies on all of the swap parts.
    • josephb983
      • Nov 2007
      • 60
      $900 is pretty cheap. really think I could get by that low?
      Did I list any other parts above that I wouldn't have to change out? How much would the engine, ecu, and harness run?
      • FredK
        • 14762
        You'd have to find the engine with the 525i oilpan, all accessories, and DME for cheap, like $600. I got my 325i M50 for $660 including transmission. I got the brake booster for $20 at the pick and pull. I got the 325i driveshaft for $20. I got the oilpan, pickup, and dipstick for $20.
        I did end up at around $1400 for the complete swap, BUT, I did a lot of maintenance parts (OE waterpump, thermostat, rear main seal, VC gasket, steel/rubber oil pan gasket, very low mile clutch, new clutch slave, etc.), and I got a lower ratio limited slip diff, new center support bearing, throw out bearing, guibo, and E36 transmission. You don't NEED this stuff, though it'd be "nice to have."
        You might need like another $200-300 to figure out an exhaust.
        • josephb983
          • Nov 2007
          • 60
          What would I have to look out for on a used M50 engine? I mean, I know the timing chain is a big issue on M42's once they get miles, as the tensioners usually are not replaced in time. Anything like this on an M50?
          What miles would a $600 M50 have on it would you think?
          • FredK
            • 14762
            120-150K. It's hit-or-miss though, sometimes you'll be able to score it cheap, other times, not so much.
            Timing chains aren't nearly as big an issue on M50 engines. I haven't heard of anyone's timing case disintegrating like on an M42. The tensioner can be easily replaced just like on the M42.
            • kolunda
              • Mar 2007
              • 136
              you can re-use your brake booster and slot the holes, that will save you some $
              Perot isn't a Hillary hater, but he's not a fan either, relating the bumper sticker he received that reads: "Monica Lewinsky's Ex-Boyfriend's Wife for President."
              • josephb983
                • Nov 2007
                • 60
                is that a booster-side modification, or engine-side?
                • josephb983
                  • Nov 2007
                  • 60
                  Looks like my parts list right now would be:
                  M50 engine
                  M50 exhaust header
                  525i oilpan
                  water pump
                  thermostat housing
                  engine mounts
                  wiring harness
                  computer/ecu
                  brake booster
                  e36 driveshaft
                  Would I need a different flywheel? What do they cost, if so?
                  What other parts am I missing from the above list?
                  • 318isbmw
                    • Nov 2005
                    • 2843
                    Depends on what transmission you use for the flywheel. If you keep the same transmission then it would be e30 m20 flywheel and clutch assembly and then the 323 TOB to make it all work out correctly. I would do brake booster and don't slot the old one... Just find a cheap 735 being parted and pull the master cylinder from that and it works w/ the ix booster(same booster) and is the 25mm size so brakes are much firmer.
                    Good luck trying to do it on the cheap, Fred's right, it does very depend the market at the time. Mine I tried to do cheap and it kicked me in the end, so spend a few extra bucks and follow what everyone else does and it'll end up working out. Good luck, its much more fun than the m42, just finished the swap last week on mine.
                    • josephb983
                      • Nov 2007
                      • 60
                      You swapped from an M42?
                      Yeah, I'd like my brakes to be firmer. Would the brake booster from a 525i work as well?
                      • 318isbmw
                        • Nov 2005
                        • 2843
                        Yes I swapped from the m42. The remnents of the m42 are laying in the garage still actually. No the 525i brakes will not work. Just look for a 735 brake setup, I got mine for 65 off craigslist and get the booster and master cylinder and you're good to go w/ a 25mm master cylinder rather than 23 I believe stock and then it is the same as the ix booster.
                        If you wanna see the tear down pics, jrhaile posted them under the the swap section of the forum on here as Brendan's swap or something like that. For any other pics or advice, hit me up, I've got tons on my facebook that my gf posted for me.
