ST front sway bar installation question..
    well...im a little confused, so i thought id see if anyone else that has the ST front bar remembers how it was installed. i have 2 thick washers and 2 plates that came with the bar, either im missing 2 washers, or theres a specific way to install it. if someone has the instruction sheet, or parts lists that would be great.
    al
    It sounds like my IE bar set. If it is the flat stock goes up against the mount (on the subframe) and the thick washer goes between the flat stock and the rear hole, to fill the gap. Then the sway bar mount goes up against it all, and is bolted in place.
    Hope that makes sense.
      ahhhhh so only one washer in each, okay that makes sense, did they provide longer mounting bolts or did you reuse the factory ones?
        I had to source new longer bolts. I can't remember if they were 5 or 10mm longer though.
        I'm not really that impressed with IE products, and doubt I will purchase any of them in the future.
          that plate lower the bar quit a bit, and doesnt sit flat where the factory mount sits, do i really need to use the plate?
