Driveshafts make my head spin...
  • Fidhle007
    I can fly, motherfucker
    • Oct 2005
    • 7209
    So I've been trying to figure something about driveshafts out but it just gets more and more confusing the more I delve into this info.
    When using the ZF tranny out of a '95 M3, you can use an E30 M3 driveshaft, a later E36 shaft or, with some modification, an ETA shaft, yes? The info I'm most interested in is the ETA shaft because that's probably the easiest to get ones hands on. The thing I've heard though, is that the Guibo bolt holes are 10mm on the shaft and 12 on the Guibo and tranny so you would need to shim it. Is drilling the shaft out not an option for safety reasons then?
    Just trying to understand this a little better...
    Thanks!
    Brendan
    '89 325is S50 Track Montser
    '04 X5 Daily/Tow Vehicle
    http://www.avarestoration.com
    http://www.myspace.com/brendanfiddle
    Click here if you want to be my zombie slave...
    http://www.youtube.com/user/Fidhle007
  • FredK
    • 14759
    I'd leave the driveshaft alone and not drill it. I'm sure you could, but any time you remove metal, for the most part, you're reducing the amount of strength.
    Just get a 96+ 328 shaft. They're a dime a dozen.
    • Fidhle007
      • Oct 2005
      • 7209
      5 speed, though, right? I think I already have an ETA shaft at the shop that would be the easy route.
      • loonibab325i
        • Dec 2005
        • 770
        agreed, I recommend a late model e36 drive shaft as well, I used the drive shaft out of a 97 m3 with an e30 center support bearing, so far I have not ran into any troubles. What I did notice though was how close the guibo was to my shift linkage.. that is some freaky stuff haha.
        s52 0-150mph & more http://www.youtube.com/loonibab325i
        • Fidhle007
          • Oct 2005
          • 7209
          I'm sorted I think. It's nice being friends with the Euro Depot guys...
          • loonibab325i
            • Dec 2005
            • 770
            what route did you go with?
            • Fidhle007
              • Oct 2005
              • 7209
              Original shaft from the M3 donor car, it has the four bolt rear end.
              • loonibab325i
                • Dec 2005
                • 770
                sweet, it bolts up to the 325e front end of the diff no problem? I never new that. What center support bearing do you use, also what guibo?
                -Abe.
                • Fidhle007
                  • Oct 2005
                  • 7209
                  No clue yet, this is all theory until I start turning wrenches next week. CSB should be E30 though, and Guibo has to me '95 M3 because both things on either end of it are from a '95 M3...
                  • loonibab325i
                    • Dec 2005
                    • 770
                    Ah, cool.
                    Keep us updated!
                    -Abe.
                    • shopkeep
                      • Oct 2007
                      • 94
                      I think I am one of the only ones that kept the same flange's from the E30 and cut the driveshaft down to length...lol....I knew a guy that knew a guy, so I got it done pretty cheap.
                      • evil_twin
                        • Nov 2007
                        • 2965
                        Alright. So I am using a ZF transmission for my M52 swap, and I need to know what drive shaft I need in order to keep my stock rear end. I know I can use an E30M3 drive shaft but I can't seem to find one cheap enough. What should I do?
                        Paypal: vdang5@gmail.com
                        Delta Auto Care
                        2875-C Towerview Road
                        Herndon, VA
                        703.435.1375
                        My Feedback Thread: Evil_Twin
                        • Fidhle007
                          • Oct 2005
                          • 7209
                          E36 328 driveshaft seems to be the route to go. I guess that's what mine is, it's not the shaft that came off the M3 but it was bolted to a ZF and has the 4 bolt rear so I'm assuming it's from a 328 originally. You won't want to keep your stock rear end though, the gearing will be waaaay too short. Fun as hell under 55 but the high rpms at highway speeds are a bitch. 3.25 works for me now, although I'd really rather have the short gears on a six-speed box instead but that's just not in the cards now.
                          • etxxz
                            • Feb 2006
                            • 2085
                            e36 M3 or 328i's have the 4 bolt rear end. those will work. Otherwise e30 M3. if your car is four door idk what your route is. There's both 328i and M3's (both 96+) that are four door.
                            No more e30s for me.
                            88 black BMW OBDII 332is dedicated track [sold]
                            88 BMW OBDII bronzit 332is [RIP 03/08]
                            91 BMW 325i [sold]
                            86 Corolla 'Ae86' HB 20v trd [sold]
                            http://youtube.com/watch?v=pTj7Hn9v5Rs
                            • broke30
                              • May 2007
                              • 1019
                              Umm I don't know where you guys got your information about the eta driveshaft but I'm using an UNMODIFIED '87 eta driveshaft on my zf.....
                              Max
