newb questions about S52 swap
  • Larry e30
    • 182
    I have an M50TU and plan on swapping that engine out within the next month with an S52. Now with the S52, I only have the block and some other parts, so I'll be using the head from the M50. So do I have to buy new head bolts? I heard not to reuse them, and also should the number one cylinder on the S52 be at top dead center when I put the new head on?
    -Larry
  • Tarn
    • Sep 2006
    • 212
    As far as the head bolts, yes you must replace them because they get stretched on install. Not to sure on the head matching the s52 so im going to leave that alone.
    • madjurgen
      • May 2005
      • 1203
      I dont think so. Head bolts arent torqued above their yield point afaik.
      As time went on, the factory developed the car each year, making it faster, more comfortable, and capable of handling at higher speeds.
      You don’t want this. You want the trickiest, most dangerous, oldest model you can find. Only then can you prove to the world that you’re a man.
      • matt
        • 3731
        Wrong. They certainly are.
        • quillbro
          • 369
          Where do you get new bolts? Is it a common thread pitch and size? Or is it a special OEM part number? Just asking cuz I'll be assembling a block and head soon
          • matt
            • 3731
            Buy them from BMW or OEM, they are sold in a set. You need to install them properly also... this is critical.
            • quillbro
              • 369
              Found a link to em on Fleabay...
              http://cgi.ebay.com/ebaymotors/Parts...3756.m20.l1116
              Install correctly? I imagine thats a Cris-Cross incremental torque pattern with a certain lb/ft torque spec? Care to tell?
              • Drew325is
                • Oct 2004
                • 520
                Head studs are not something I would be going to ebay for. Also, buy a good workshop manual (e.g. Bentley) and follow the correct 3-stage torque-down procedure.
                • quillbro
                  • 369
                  They're from Bavauto recycling and supposedly new... but yeah im a newb at these things anyway...whats a good source? Id rather not lay out 189dollars for the APR ones.
                  • Drew325is
                    • Oct 2004
                    • 520
                    I'd just be going somewhere I'm 100% sure of (maybe that's Bavauto Rec - I have no experience with them, and am not trying to knock them)...but in this case I'd just suggest having some local accountablility and maybe get some technical advice as well.
                    • Van Westervelt
                      • 9365
                      Just pick them up at the Dealer. They are only like $40. Or call up BMAparts.com and make an order for them.
                      • broke30
                        • May 2007
                        • 1019
                        Those are not head studs. And to the original poster, BMW oem head bolts as Matt said ARE torque to yield. Head STUDS on the other hand are not, in most cases you can reuse head studs. A new set from pelican is dirt cheap, I don't know why you would even think about reusing the old ones to save like $30......
                        Max
                        • Drew325is
                          • Oct 2004
                          • 520
                          Max
                          Sorry, meant bolts...and I agree with not reusing them.
                          • Larry e30
                            • 182
                            Alright cool, is there anything else that shouldn't be reused other than gaskets?
                            • gobuffs
                              • Dec 2004
                              • 513
                              If you are asking these questions, do you have the know how and abilities to undertake such a project?
                              And on the reusing head bolts....this debate is ongoing on S14, there are reputable engine builders that say they can be reused, some say to get new. I have friends that have reused them with no ill effects.
