Swapping NV M50 to Vanos M50
    • 37829
    Not exactly E30 related...
    Say I have a E34 with a non vanos M50 in it and I want to swap a newer Vanos M50 in to it, what's needed? I know it will obviously bolt in but what kind of wiring needs to be done or changed?
    Thanks guys.
    Classic BMW Specialists
    Grover Beach, CA
    www.BimmerHeads.com
  • matt
    • 3731
    You'll need the ECU and harness from the newer motor. Intake manifold/injectors/exhaust/etc should be the same.
      • 37829
      It should plug in to the car and work with the correct ECU and engine harness, yes? Or is custom wiring needed?
      Grover Beach, CA
      www.BimmerHeads.com
      • matt
        • 3731
        Should plug right in, if the NV plugged right in.
