Zf tranny...what diff?
  • quillbro
    • 369
    If i use a Zf Trans im under the impression that i can use a 96+ 328driveshaft or e36 m3 96+ shaft.
    I also need to get a shorter ratio Diff. Does anyone know a specific year (e36) and model that has something around a 3.25 I need to know so i can call the junk yard and try to find one.
    Is there and modifications that need to be done to mount an e36 diff to an e30 chassis?
    Thanks.
  • broke30
    • May 2007
    • 1019
    Uhhh yea, it won't work. An e36 diff housing is the farthest thing from an e30 one. Search... And you can get a 3.25 that will bolt up to the e30...
    Max
    • PiercedE30
      • Apr 2005
      • 4220
      Look at E28's for 3.25 diffs. That's where I got mine from (only using it for driving to the Picnic).
      My 2.9L Build!
      • e30serg
        • Dec 2006
        • 562
        You should be able to use an e36 m3 3.23 diff by changing the cover to the e30 one.
        The usual thing to do is : e36 m3 zf tranny with e36 m3 diff or e30 tranny with e30 diff. It keeps the ratios street-able.
        • Mike B.
          • Jan 2006
          • 987
          ^^^ Nope!
          The E36 diffs (M3 or otherwise) will not mount to the E30 chassis even with a rear cover change.
          Look for E28 diffs like Pierced says. You will need to change out the rear cover and output flanges to run on an E30.
          • matt
            • 3732
            Nope, not even close. An e36 diff only shares internal parts with the e30 diff. They are 100% not compatible.
            You can swap the rear cover off an e24 or e28 diff and put that in an e30. That's where you can find the 3.25 and 3.46 ratios that are perfect for the e36 trans.
            • sharksforthecup
              • Aug 2007
              • 246
              You can also use the e23 with the rear cover and flanges swapped, That's what I have.
              • e30serg
                • Dec 2006
                • 562
                Learn something new everyday! Sorry for the bad info. I really thought it was usable.
                Hmm. I do have an e28 533i sitting in front of my house....
                • cheades
                  • 632
                  MZ3 came with a 3.23 that bolts right up also.
                  • 1990m3
                    • 1180
                    true, I got one sitting in the garage!
                    • windsor318is
                      • Mar 2004
                      • 688
                      another suggestion is a 2.93 from an ETA they also have LSD, and its a direct swap.
                      • quillbro
                        • 369
                        So if i find an LSD from an e28 i can just swap the cover off my e30 and it will mount right up?
                        I think they have 4 bolt input shafts...
                        Im guessing so does the 96+ 328 and 96+ m3?
                        • e30polak
                          • 6136
                          And the out put shafts for the axles, which pop right out :D
                          INSTAGRAM: @UNDR8D_EMPIRE
                          • etxxz
                            • Feb 2006
                            • 2085
                            Use the backcover and flanges from your current diff (or new/junkyard one) the back cover just unbolts easily and the flanges will pop out easily by prying them
                            yeah. you got it.
                            ...now word of advice. a ZF + 3.25 = g260 + 4.10 (~2% off) so its really short. tranny gear rations also change. ~ 70mph at 3300rpm on stock 14" rims. do what you must. zf choices are eta's 2.93 or e28's 3.25. some people do 3.64's but they are crazy.
                            No more e30s for me.
                            88 black BMW OBDII 332is dedicated track [sold]
                            88 BMW OBDII bronzit 332is [RIP 03/08]
                            91 BMW 325i [sold]
                            86 Corolla 'Ae86' HB 20v trd [sold]
                            http://youtube.com/watch?v=pTj7Hn9v5Rs
                            • PiercedE30
                              • Apr 2005
                              • 4220
                              I like the 3.25 + G260 for some reason. I put it in today. The 4.10 is nice also, but the 3.25 is going to be good for highway.
                              My 2.9L Build!
