Gaskets which to use..
  • Mako18
    • Jul 2006
    • 688
    I recently aquired a 94 m50b25 I am going to replace all the gaskets before she gets dropped into my e30. What I am consdering is buying a complete engine gasket set off ebay for $150 and discard the valve cover and head gaskets. I will use only oem for these ...
    What are you guys using? Are there any other gaskets to be concerned about that are prone to fail?
  • matt
    • 3732
    None of the gaskets are prone to failing, honestly. The valve cover gasket is probably the most likely to leak, but a little RTV will fix that right up.
    • FredK
      • 14764
      Does the engine NEED a new head gasket? If it is fine, I'd leave it alone!
      • PiercedE30
        • Apr 2005
        • 4220
        If anything, replace the oil filter housing gasket.
        My 2.9L Build!
        • Mako18
          • Jul 2006
          • 688
          Yea. I am going to do a leak down later this week then I will start buying what I need. I just like to get a game plan. Plus its easier to do it all at once on the engine stand instead of doing it in the car, nothing like a bad oil leak when your 30+ miles from anything enjoying the back roads. <-- thats 1 reason I now have a 87 Toyota Supra (turbo).. dumb friend wouldn't fix a minor leak that eventually became a huge leak and costed him a 4k engine build lesson learned from the grandstands.....oh well car is mine now...being built correctly..
          • matt
            • 3732
            Is that an HP2 sport in your avatar?
            • Mako18
              • Jul 2006
              • 688
              Yeah its one sexy beast!! Its on my list ...well after some form of SM (prod a DRZ400sm) for the adventures around town and through the woods..
              • matt
                • 3732
                The shop I work for sponsors Nate Kern. I have a DVD of him doing about 5 qualifiying laps around Barber on one, shot by the Speed cameras before the last Formula Xtreme race. It's definitely a badass bike.
                • Mako18
                  • Jul 2006
                  • 688
                  OK I got a little confusion to clear up. I have a 94 m50b25 (vanos).
                  The harness I am getting is from a 96 525i & the ecu is missing. What ecu do I use, the marron 413? From what I have researched the harness should work with my engine! (confirm?) but I have also read I may have issues with a harness adapter such as AKG's because a 525 harness its a bit different from a 325i harness!?!?!?!.WHY?.... I have researched but it seems a little confusing I am getting conflicting answers.
                  Hopefully someone knows...I am going to pick up the harness now.
                  • matt
                    • 3732
                    There was no '96 525... Production of the e34 525i stopped in 12/95 and production of the e39 525i began in 04/00.
                    If you have a '95 525i harness, you need a silver or red label 413. Silver label will need a new chip.
                    • Mako18
                      • Jul 2006
                      • 688
                      Yeah its a 95 I got my cars mixed up.
                      • Mako18
                        • Jul 2006
                        • 688
                        ok and now just for shits and giggles. which is better/less work to use a 525 harness or 325? I assume the 325 but since its going into a e30 now it might not make a difference. Whats your thoughts?
                        Later down the road I do plan on a turbo growing somewhere under the hood. I want to make sure I can encompass my future needs. Useable power will be the goal! not peek power/dyno queen
                        anyway back on the off topic..hahaha.
                        • matt
                          • 3732
                          There are tradeoffs. I dont remember all the specifics since I've never seen them both together. I may have both laying around the shop right now though... I will look Wednesday.
                          • Mako18
                            • Jul 2006
                            • 688
                            sounds good. I didn't get the 525 harness I ran out of time and they wanted to go home..all I needed was 10 min it would have been out...Can I cut the harness that goes to things like headlights and stuff I wont need? The e30 is wired so much nicer very user friendly...damn e34/e36...
