Issues with s50
  • Am pM HooDluM
    • Aug 2007
    • 72
    Issues with s50
    I'm having some issues with the way my car is running. Basically it ran perfectly fine till I drove it today. I got on a little bit today took it no higher than 6k when getting on it. Car didn't have the O2 hooked up yet, when I got off the freeway the car would basically just die. Check all the fluids they were all good. Reset the ECU (remove power for a few min then hooked back up) Car would start and idle rough around 400-500rpm. Some loss of power at low end, top end is still good.
    Run a compression test on it 180-130-0-190-0-0. Weird thing is that we couldn't get any compression on cylinders 3, 5, and 6. Which doesn't make any sense, there is no smoke or anything coming from exhaust. Plugs look all good not in fuel or oil coated at all. Got the O2 hooked up, didn't make a difference, thinking the fuel map was just dumping fuel. Took the valve cover off and everything looked good.
    FYI, no money shift or coolant in oil ;)
    Any ideas on what could be checked next?
    Mikey
    -= Epitom3 =-
  • static
    • Oct 2005
    • 501
    well, the next step should be leakdown to determine where the compression goes in those cylinders (i.e where it leaks out)
    perhaps you blew the gasket
    when/if you open the engine , don't forget to change retainers for newer style
    good luck
    • matt
      • 3732
      Sounds like a head gasket... or bent valves.
      • e30pwr
        • Oct 2007
        • 642
        How old was the motor when you got it and what rebuild if any? Could be compression rings but with 3 cylinders going out that fast I'd say head gasket.
        • Am pM HooDluM
          • Aug 2007
          • 72
          Thanks guys. The next idea I had was to pull the head. I'll do the leak down test, and go from there. Just wanted some outside opinions. ::thumbsup::
          Mikey
          -= Epitom3 =-
