Some m50 swap questions
  • BMWE30iS
    • Jun 2007
    • 288
    Hello everyone, i am in the process of doing a m50 swap on my e30. I am using the M50 with the stock 260 trans, and also using the clutch and flywheel from the m20, my questions are is there any modifications needed to run the m20 clutch and flywheel with m50 and also can i used the m20 started on the m50.
    thanks Dan
    Current:1995 :540i--m60+6speed+bunch of other goodies(supercharged) hehe
    1995 525i-5, new winterbeater/DD
    In the past
    1987 300sdl(winterbeater/DD)
    1990 325iS caged and m50ed plus a whole bunch of other stuff!
    1995 540i-6 speed oxford over parchemnt
    1990 BMW 325i(s)Brillantrot with black int
    1995 Audi A6 5speed
    1991BMW750il
  • BigD
    • Jul 2006
    • 1085
    Hi Dan,
    Yes all of the above is possible. You will have to file down some bits of the oil pan in order for the flywheel to clear. You'll see when you get there - just take it a bit at a time.
    The starter is not only possible but required - the M50 starter is not compatible with the M20 ring gear.
    The only other thing you will need to do is to figure out a mount setup for the transmission brace. The angle of the M50 is different from the M20. There is a guy here who makes a custom brace which will use your stock transmission mounts. Or you can use an E24 mount for the driver's side, and any 1" tall mount of your choice for the passenger side. You also have to bend your selector rod very carefully, to keep the shifter vertical.
    • smonkbmw
      Professor
      • Jun 2006
      • 4549
      shave the stock flywheel as opposed to filing the oil pan. less rotational mass is a benefit to this also.
      • madjurgen
        • May 2005
        • 1203
        Has anyone made an M20 JBRacing flywheel work with a 24v motor/G260 combo?
        As time went on, the factory developed the car each year, making it faster, more comfortable, and capable of handling at higher speeds.
        You don’t want this. You want the trickiest, most dangerous, oldest model you can find. Only then can you prove to the world that you’re a man.
        • Charlie
          kid tested, administrator approved
          • 6686
          Yes, I'm running it right now. It kicks ass, do it.
          -Charlie
          Swing wild, brake later, don't apologize.
          '89 324d, '76 02, '98 318ti, '03 Z4, '07 MCS, '07 F800s - Bonafide BMW elitist prick.
          FYYFF
          • el_gringo
            • Mar 2008
            • 299
            uh. secks.
            • FredK
              • 14759
              cool engine cgrizz
              • PiercedE30
                • Apr 2005
                • 4220
                I'm with Charlie on that one. I've got a JBR flywheel on mine.
                My 2.9L Build!
                • madjurgen
                  • May 2005
                  • 1203
                  -Charlie
                  Sweet. Any flywheel shaving or oilpan grinding necessary?
                  • Nick325is
                    • 1409
                    I've got a JBR flywheel bolted to a 260 tranny as well. No clearance issues with the oilpan. I can't wait to get this thing running!
                    -Nick
                    • BMWE30iS
                      • Jun 2007
                      • 288
                      thanks guys, so i decide to use the e24 black hex mounts how do these work with the e36 arms? who has used these
                      In the past
                      1995 Audi A6 5speed
                      1991BMW750il
                      • Kerrath
                        • Jun 2008
                        • 577
                        I see ebay headers. ;) Just like mine.
                        I ended up using M50 flywheel with M50 starter cuz I was having problems getting the M20 starter to fit my block and shaving down the oil pan wasn't helping much. Nobody would shave the flywheel for me and we were pretty terrified of trying to shave it balanced ourselves.
                        For the tranny brace used an E30 engine mount and 2 1/8"ish steel washers there and one where the brace bolted to the car.
                        I've still got problems with my shifter though. Right now it's driveable with 4 gears, but I want my overdrive! It's an early model so the plate where it bolts to the tranny in two places got rotated with the tranny. The fixes for the late model shifters seem easy, just a bend or cut'n'weld job, but to get the shift plate centered and to seal the opening with the foam, I'm sure there's gotta me more done to get it working right.
                        Anybody have experience with that?
                        • Mako18
                          • Jul 2006
                          • 688
                          when using the jb flywheel what starter did you guys use? Im guessing m20 but wanna be sure!!
                          • golde30
                            • 11464
                            starter must match the flyweel.
                            IG: @Baye30
                            • dpgrand
                              • 179
                              -Charlie
                              -Nick
                              What clutch are you all running? Also what pressure plate?
