Spark + Fuel + Air = no start WTF
  • Beej '86 325es
    • 2639
    Title says it all, I've got good spark and fuel but it's just cranking not even trying to start.
    I checked spark at all cylinders and it's ok.
    I checked the injectors, but they're basically just dropping drips fuel. Shouldn't it be spraying? I'm assuming this has got to be my issue.
    Any thoughts?
    Oh - and photos of the car that hasn't run in 3 years...
    -Brandon
    '86 325es S50
    '12 VW GTI Autobahn DSG
    '03 540i M-Sport (sold)
    '08 Jeep SRT-8 (sold)
    For sale:
    S50 TMS chip for Schricks
  • dsobering47
    • Oct 2007
    • 697
    do you have fuel pressure? is the starter engaging at all? compression? did you mess with the EWS at all?
    • DaN
      • 1265
      What's ur fuel pressure?
      • Danny
        • 14216
        Are the injectors dirty?
        • norwood e30
          • Mar 2007
          • 442
          That check all relays and injector wires as well.
          • Charlie
            kid tested, administrator approved
            • 6686
            Fuel pump relay
            Ground from the block to the frame
            Ground from the rail to the head
            Fuel Pump
            Reseat the chip in the DME.
            You do have the right hoses connected to the right ends of the rail, right?
            -Charlie
            Swing wild, brake later, don't apologize.
            '89 324d, '76 02, '98 318ti, '03 Z4, '07 MCS, '07 F800s - Bonafide BMW elitist prick.
            FYYFF
            • e30this
              • 3580
              is your ecu bolted in the stock location??
              if your not getting good ground to it then your car wont start.
              make sure your battery is charged too.
              • gobuffs
                • Dec 2004
                • 513
                Tap to unclog the injectors or send them out to be cleaned. 3 years makes it almost guaranteed they are clogged.
                • Beej '86 325es
                  • 2639
                  All good thoughts guys.
                  -Some things I know are ok:
                  -Ground from block to frame
                  -Ground from rail to head
                  -New 24lb injectors
                  -No EWS (507 DME)
                  -Starter is cranking motor
                  -New optima battery
                  Things I'm going to check:
                  -Double check fuel is flowing in correct direction through rail, after that check fuel pressure
                  -Mount DME in glove box (just sitting in there now)
                  Thanks for the input guys, I'll let you know what happens!
                  -Brandon
                  '86 325es S50
                  For sale:
                  • 318isbmw
                    • Nov 2005
                    • 2842
                    Fuel flow was my issue when I did mine. Had it connected the wrong way. You'll know though when you take line off the rail, it'll squirt from the pressure if it was on wrong.
                    • windsor318is
                      • Mar 2004
                      • 688
                      could you explain this a little more, what did you have hooked up wrong? i had fuel sqiurt when i removed the fuel line at the front of the motor..
                      • 318isbmw
                        • Nov 2005
                        • 2842
                        I had the lines backwards so it just held the pressure in there but couldn't pump since it was wanting to go in the wrong direction. Basically meaning I had the pump working because I had pressure, so therefore the lines must be wrong since it had pressure but wasn't putting it into the cylinders.
                        • Mr.SWISS
                          • Nov 2005
                          • 1251
                          The lines hold pressure no matter what way you hook them up. However this is a VERY common mistake amongst swappers, and a good thing to check on a no start. Have you tried verifying it as a fuel issue by spraying some starting fluid in the below and cranking it to see if it sputters?
                          Originally posted by 325Projectz
                          don't listen to the diagram... listen to mr. swiss.
                          :nice:
                          • 318isbmw
                            • Nov 2005
                            • 2842
                            Yeah, I was meaning as you know the pump is working so therefore it must be the lines since its got pressure.
                            • BDSax
                              Junkyard King
                              • Mar 2006
                              • 3594
                              good to see its almost there!
