m50 got wet
  • base146ball
    • 12
    m50 got wet
    I have a friend with a M50 swap the car was driven through a large amount or water then about 5 more miles after he turned it off it wont start again. Anyone have any suggestions on where he could look or what he could try doing?
    Thanks again
  • Jason89i
    • Sep 2004
    • 875
    Thanks again
    hey frank.
    if he does not have the plastic coil cover (valve cover hider), he might have got water into the spark plug recesses. pull coils, straw taped on end of shop vac (to get water out so it doesnt go into combustion chamber) pull plugs, wipe dry. seen it twice. cheers, jason
    • quillbro
      • 369
      huh just pressure washed my motor yesterday and i thought the coil packs would be fine.... that'll be something to do i guess before i drop it in. Thanks
      • base146ball
        • 12
        false alarm he was asking for help before he even check to see if there was fuel.
