Gearing options
  • e30polak
    • 6136
    Gearing options
    Hey guys, I want to go with some shorter gears and wanted to check my options.
    I'm using the e36 ZF with my swap, and a 3.25 LSD.
    I was thinking a 3.46 ring and pinion from an e24/e28, but I don't know if that will really shorten the gears enough.
    I originally had a 4.10 open and it wasn't drivable because 1st was soooooo short, but how would a 3.73 be???
    Also does anyone know if there is a 3.64 ring an pinion available from any e30/e24/e28??? I think that would be a decent upgrade but still drivable, since I DD my car.
    Please discuss.
    INSTAGRAM: @UNDR8D_EMPIRE
  • BigD
    • Jul 2006
    • 1085
    Just work the math. Figure out what rpm you could live with for your most common cruising speeds and pick the diff closest to it. I wouldn't want anything shorter than 3.25, and it's a track car. I wasn't even a big fan of 3.73 with the Getrag.
    • hugh jass
      • 2220
      I've got a Getrag 250 and a 3.25 rear end and can't imagine anything shorter. i still spin at about 3k at 70-75 and wouldn't want any higher rpms than that
      ______________________
      ex-Chief Operating Officer
      Blunt Tech Industries
      West Coast and Pacific Rim
        • 37827
        I wouldn't go over a 3.46 with that. I've got a 3.73 with the E30 260 trans and I'd like to go to a 3.91 for just that little bit.
        Classic BMW Specialists
        Santa Clarita, CA
        www.BimmerHeads.com
        • matt
          • 3731
          All of those are pretty easy to find in the e30 medium case.
          • pedal2metal
            • Jun 2007
            • 93
            Just finished my swap a week or two ago (using e30 getrag 260), and I left the 4.10 lsd in there just to see if I could live with it. 1st gear is preeeeety useless, I'm thinkin the same thing as Mr 325: 3.91 is probably the right choice if using the getrag 260. Anybody got one for me?
            • e30polak
              • 6136
              Matt which models/years came with the 3.64???
              Also was the 3.64 in lsd?
              • e30polak
                • 6136
                You think its bad with the e30 tranny try a 4.10 with the e36 zf!
                I red-lined 1st at 21 mph at 7200! (but the torque was fucking ridiculous between 2nd-5th!)
                I think a 3.73 is what most people use with the e30 getrag.
                • e30pq
                  • Apr 2006
                  • 579
                  I believe the M Roadster (Z3) came with a 3:64 LSD.
                  I'm using a Getrag 260. I had a 4:10 LSD in for a year. That gear ratio was too short. I just installed a 3:73 LSD and I think it's perfect.
