735i booster install. A few questions???
  • jfdmas
    • Jun 2008
    • 16
    well, i just recieved my 735i booster i ordered online from a bone yard and it didnt come with the extension piece that attaches to the booster. Now i recall reading somewhere that people were eliminating this piece? does anybody have information on how to install this booster without the extension bracket?
  • matt
    • 3731
    Nope, but I'll send you one on Monday for $10.
    • jfdmas
      • Jun 2008
      • 16
      im pretty sure people found a way to install it without, however if i dont find out how by monday i will buy one off you matt. thanks.
      • Charlie
        kid tested, administrator approved
        • 6686
        Are brakes really one of the items you want to "find a way to make it fit" vs using the proper method?
        -Charlie
        Swing wild, brake later, don't apologize.
        '89 324d, '76 02, '98 318ti, '03 Z4, '07 MCS, '07 F800s - Bonafide BMW elitist prick.
        FYYFF
        • jfdmas
          • Jun 2008
          • 16
          -Charlie
          ughh, people have mounted them without the spacer by making some modifications. I just want to know how they did it. Then ill use judgement to whether or not i will go about it. the extra clearance would be nice.
          • brandon11130
            • Jan 2008
            • 635
            you will have to drill out new holes in the firewall, the ones there are too close together, which means drilling through the pedal assy as well. IIRC the 735i booster only has 2 bolts coming through the back. I think it would be better ising the spacer, plus then you dont have to cut and re die the shaft
