I can't figure it out!  I replaced the transmission seals before I completed my swap.  I don't appear to leak any oil when driving on the street, but every time I get off the track I have oil dripping onto the cats and whiffs of smoke coming out from under my car.    Everything in front of the tranny and bellhousing is dry.  The fluid is very clean and has to be trans fluid.  The underside of the car is wet with oil from the rear of the tranny and back.  After 3-4 track days, I found the tranny .5L down - total capacity is 1.2L.  I topped it off and went through the PITA to re-replace both rear seals.  No oil leaking after a few days of street driving.  Everything looked good until I ran another track day and more smoke.
Maybe it's leaking out the top vent?? Or, maybe it's plugged and pressure is building up inside the tranny? The car gets run hard at the local track - lots of time above 100 mph. I'd suspect that being a problem, but plenty of e36's never have this problem. I'm using Royal Purple transmission fluid. Same stuff that I've got in my e36 m3 and I've run that car at the track too. I'm about ready to give up and resign myself to toping the fluid off after every track event. Any ideas? Maybe I should try fitting a vent catch-can?
