How do you get the oil dip stick tube in?
  • shiboujin
    • Feb 2006
    • 2791
    I've never actually had to put a dip stick tube in but my oil pan came with out one. I have the tube but it doesn't seem to fit in easily. I could smash it on but I would rather figure out what to do first.
    Anyone?
  • BigD
    • Jul 2006
    • 1085
    Bash it in with a wooden block. As you hammer make sure it stays aligned properly. Don't forget a new o-ring.
    • shiboujin
      • Feb 2006
      • 2791
      eh? theres an O ring? Gasket maker FTW!
      • FredK
        • 14763
        It slides right the crap in when you have the manifold off.
        • shiboujin
          • Feb 2006
          • 2791
          *shrugs* maybe I got the O ring stuck in there. I havent been trying too hard on it lol.
          • BigD
            • Jul 2006
            • 1085
            I don't think it's supposed to just slide in. I'm pretty sure it's designed to be pressure fit. That's what the instructions say and that's what my experience was.
            • shiboujin
              • Feb 2006
              • 2791
              Gotcha, thanks for the info.
              • golde30
                • 11464
                they slide rite in, no pressure necessary. mine wouldnt go in easily in the beggining either, it was b/c there was an O-ring sitting in there sideways keeping me from making penetration. if you push that o-ring in there, yer gonna have to pull the oil pan, and thats no fun.
                IG: @Baye30
                • 1990m3
                  • 1180
                  mine slides in and out pretty easily as well. I tried putting a block of wood on top and tapping it further down with a hammer but it won't go. It's definitely right where it should be and slides in and out easily. i need a bracket to keep it from wiggling around. And I am using the o-ring
                  • BigD
                    • Jul 2006
                    • 1085
                    I dunno, mine wasn't touching the manifold and it would only slide in on its own so far, and the o-ring was up by the groove, it was not in the way. Were you guys using used tubes or something? Well either way, I think point is that if it's not going in on its own, it's normal and just tap it with a block of wood or something. As I understand it, that groove on it is designed to pinch the o-ring against the pan, so it should be down that far. I just kept tapping until it made a less hollow sound upon impact.
                    • shiboujin
                      • Feb 2006
                      • 2791
                      • brandon11130
                        • Jan 2008
                        • 635
                        what is the tab off the tube supposed to bolt to?
                        • golde30
                          • 11464
                          i thought you would like that terminology...
                          IG: @Baye30
                          • brandon11130
                            • Jan 2008
                            • 635
                            I have this big hole coming off my stick, i want to put a big bolt through it and maby stick it into another hole and fasten it tight, does anyone know what hole i should stick this bolt into?
                            • BigD
                              • Jul 2006
                              • 1085
                              It's supposed to bolt to the forward support brace of the intake manifold. But it doesn't reach the E36 version so you need to make a little extension. I did, no big deal. But after I did I realized that all you probably need is the support brace off an E34 and it'll bolt directly on...
