hi, my friend and i are swapping an m50 into his '86 e30. we have most of the parts for the swap, but are unsure about the electronics. should we use the e34 m50 wire harness or e36 harness? which ecu? assume the engine is from an e34. thanks
e34 or e36 engine harness?
e36 is best. E34 is about 6 inches shorter so you'll have to make it longer to be able to get the ecu into the glove box or make a case under the engine bay. e36 eliminates that issue and your able to fit it in the glove box in the ecu holder. I would look for a red 413 ecu...Originally posted by lifeiskaos View Posthi, my friend and i are swapping an m50 into his '86 e30. we have most of the parts for the swap, but are unsure about the electronics. should we use the e34 m50 wire harness or e36 harness? which ecu? assume the engine is from an e34. thanks
Brendan
Not to make you look dumb man, but i used a e34 harness for my m50 swap and the harness goes into the glove box with no issues and easily reaches.e36 is best. E34 is about 6 inches shorter so you'll have to make it longer to be able to get the ecu into the glove box or make a case under the engine bay. e36 eliminates that issue and your able to fit it in the glove box in the ecu holder. I would look for a red 413 ecu...
DanCurrent:1995 :540i--m60+6speed+bunch of other goodies(supercharged) hehe
1995 525i-5, new winterbeater/DD
In the past
1987 300sdl(winterbeater/DD)
1990 325iS caged and m50ed plus a whole bunch of other stuff!
1995 540i-6 speed oxford over parchemnt
1990 BMW 325i(s)Brillantrot with black int
1995 Audi A6 5speed
1991BMW750il
Interesting, didn't stretch when funk and I tried...Originally posted by BMWE30iS View PostNot to make you look dumb man, but i used a e34 harness for my m50 swap and the harness goes into the glove box with no issues and easily reaches.
Dan
Are you able to mount it in the ecu tray, just curious? Wonder if we were just retarted there. It was midnight...
I heard it is shorter, but it's not something that zip ties can't fix.I got a fender roller now! LMK if you need me to roll your fenders or want to rent the tool from me locally.
Paypal: vdang5@gmail.com
Delta Auto Care
2875-C Towerview Road
Herndon, VA
703.435.1375
My Feedback Thread: Evil_Twin
Worst comes to worst, you extend the wires, no biggie.I got a fender roller now! LMK if you need me to roll your fenders or want to rent the tool from me locally.
Delta Auto Care
Herndon, VA
703.435.1375
if you're going to go with an M50 non-vanos engine you will need a 402 Red label ecu. If you are going with an M50 WITH vanos engine you will need a 413 Red label ecu.
If you go with the M50 non-vanos engine, I have a 402 ecu that I need to sell quick.I got a fender roller now! LMK if you need me to roll your fenders or want to rent the tool from me locally.
Delta Auto Care
Herndon, VA
703.435.1375
honestly, e36 IS longer. I have used both and have a e34 harness on my car, sure zipties work, but with the e36 harness you can use the 91 318iS dme holder above the glovebox. With my e34 harness, its a huge pain to use the s14 wiring harness cover in the engine bay and have a clean above glovebox install....
Originally posted by evil_twin View Postif you're going to go with an M50 non-vanos engine you will need a 402 Red label ecu. If you are going with an M50 WITH vanos engine you will need a 413 Red label ecu.
got an m50 from a wrecked e34 at the scrap yard today. wire harness was there but no ecu... how much?
damn, we got the e34 harness... figured it would be easier to get everything from an e34 because the oil pan and such was already there, and the harness was in tact. so there's no way the harness will reach the ecu in stock e30 location?Originally posted by Mot View Posthonestly, e36 IS longer. I have used both and have a e34 harness on my car, sure zipties work, but with the e36 harness you can use the 91 318iS dme holder above the glovebox. With my e34 harness, its a huge pain to use the s14 wiring harness cover in the engine bay and have a clean above glovebox install....
