Whats up everybody. I'll try to make this short and to the point, but i'll give you a little heads up on the situations.
Got a nice clean coupe (see sig) to put a motor in. The M20 is fine, but of course, I want more power. Bought an S52, planned on doing all bolt-on's, cams, and the likes - with a goal of 250whp. After some research, and seeing numerous dissappointing dyno graphs of worked S52's and US S50's - I came to a final decision of what i'm doing.
The plan is to install a stock OBDII S52. Maybe put on the m50 manifold and a lightweight flywheel. Not going to bother spending money modding it, as the best money spend modding is going Euro s50b32. It is obvious from the dyno's i've seen. WORKED N/A s52's with $15k into them are still only putting down 260whp, where as euro s50b32's are putting out 270whp stock. It's a no brainer, IMO (I like N/A). In a year or two when I am bored of my s52 and already have at least one swap under my belt, I'll go s50b32 and sell my s52. Thus, no stupid amounts of mod money (or hopefully any other money) for my current s52. Even going to use the e30 drivetrain.
Anyway, that is the direction I have for my project. I got my motor on the stand yesterday, and started tearing everything down today with the help of a good friend. There are few question marks we've run into.
1, We tried to give it a compression test while on the stand. I put about a gallon of oil in the motor, we then pulled a spark plug and cranked the motor by hand. ~30psi in cylinder 1. Was very hard to crank, at the suggestion of my old man, we pulled all plugs to ease the cranking (we're not testing the other 5 cylinders, so why work through their pressurizing sequence was our thought process.)
We got:
cyl 1 ~30psi
cyl 2 ~30psi
cyl 3 ~75psi
cyl 4 ~70psi
cyl 5 ~0-5psi
cyl 6 ~30psi - dont quite recall, was not 0 like #5 though.
We tried using our air gun, but not enough torque to turn the crank over. Can these results be relied on to tell us something or not?
Upon inspection of the block, there was a couple things. 1st, the intake mani was obd2 not obd1 like the PO said (i spoke to him and thats a seperate issue). 2nd, there is oil seepage from the headgasket. I'll post pics in a minute. 3rd, exhaust valves are toasty. IMO, looks like motor was running lean. PO did have an m50 manifold installed, but upon pulling motor form wrecked car, noticed it was cracked - so reinstalled stock obd2 manifold. I believe it ran lean from an m50 manifold and no software. Lastly, when we pulled the coil packs, they all were suctioned very nicely and VERY clean. EXCEPT for cylinder 5, which happens to be same cylinder we got no pressure from. It looked like it had dried up oil on it. Car was wrecked in april or may of this year, so hasn't been sitting too long. Just trying to throw out all and any information I know for you guys to analyze. I'm a motor swap virgin.
My questions is what would you do in this situation. Those compression numbers mean anything the way we tested it? Does head gasket need to be replaced? Valve seals bad? piston rings?! Just drop it in the car and see how it runs?!?! tell me tell me?!!?#!?
Anyway, in all serious it looks like (again, imo) headgasket should def be replaced - as much as I dont want to spend the money
. What else should I be concerned about?
Pictures coming shortly.
Thanks for your time!
-mike
Engine after work:
Engine now:
One pic of the other side. No leakage. Wetness is from some coolant still in hoses.
We got:
cyl 1 ~30psi
cyl 2 ~30psi
cyl 3 ~75psi
cyl 4 ~70psi
cyl 5 ~0-5psi
-mike
Engine after work:
Engine now:
