ZF Transmission Mounting options
  • Dissembler
    • Jul 2008
    • 153
    My motor will be back from the machine shop soon, so I really need to kick ordering parts into high gear. Just 2 things im not sure on, and believe me I've searched this a lot.
    My motor is an M52, i know i need the oil pan out of an m50 525i along with dip stick and oil level sender, but what about the oil pick up? From what I can see the oil pick up a lot different, goes to the front of engine on 3 series and stays at the back on 5 series correct? I haven't got my pan yet so I'd like to know before i purchase anything.
    Second, E21 tranny mounts, does any one know a good site where I can get urethane versions, or conversly, do the one made by IE fit with the m50/2 ZF 5 spd swaps
    Thanks for your help
    Graeme
  • PiercedE30
    • Apr 2005
    • 4220
    Pick up tubes are reversed from what you said. You need the pickup tube from the 5 series.
    My 2.9L Build!
    • Dissembler
      • Jul 2008
      • 153
      oh yeah, lol, was thinking about it backwards, thanks pierced. Any ideas about those tranny mounts?
      • PiercedE30
        • Apr 2005
        • 4220
        No clue. I'm using a G260 with a cross member I made from 1.5" flat steel.
        My 2.9L Build!
        • justin_l_
          • Jun 2007
          • 1079
          I just used e21 mounts from bavauto.com they were designed to hold the tranny in the e21 with only one so they are pretty rugged.
