overheating m50
  • Money$hit
    • Mar 2008
    • 1604
    overheating m50
    I think Im losing coolant somewhere, but I cannot detect it. The car runs fine when Im driving, but in traffic it likes to get hot. Is this common? Engine is an NV M50.
    What can I do to remedy this? Ive searched but I guess I cant find the answers to my question.
  • FredK
    • 14761
    What kind of fan are you running?
    • Money$hit
      • Mar 2008
      • 1604
      It looks stock, im not really sure, im the 2nd owner.
      Are there any indicators I should be looking for? I mean its driven off of the engine, its not electric or anything.
      • FredK
        • 14761
        The fan clutch could be dead. If it is completely toast, you can try stopping it with a folded up newspaper while the engine is on. If there is little to no resistance, then it is shot.
        • Money$hit
          • Mar 2008
          • 1604
          Nice, Ill go try this. Thanks!
          Next I guess I have to figure out my coolant deficiency....
          • Money$hit
            • Mar 2008
            • 1604
            Yeah, its fried. I guess Ill be replacing that. Maybe it will help my cooling issues.
            *edit*
            wow, fan clutch, nicht cheap. Im getting $109 from pelican, is this about accurate?
            • FredK
              • 14761
              Sadly a brand new fan clutch is not cheap no matter where you get one. Just make sure you get the right one, because it's more than likely the fan is an M20 unit, because the M50 fan won't fit.
              Coolant can sometimes weep from a failing water pump and never make it to the ground. That is one of the best-case scenarios. The heater core might be leaking. Are the insides of your windows fogged up/greasy at all?
              • Money$hit
                • Mar 2008
                • 1604
                good point, i was looking at m50 parts.
                *edit*
                Which is the better part Behr or Sachs?
                • FredK
                  • 14761
                  I'd trust either brand. I don't remember what M20 fans look like exactly, but make sure the number of bolts / mounting styles are identical. I think some fans had 4 bolts and some had 3? I forgot.
                  • Charlie
                    kid tested, administrator approved
                    • 6686
                    What T-stat you got in there? The stock 92 degree one seems a little extreme for that motor.
                    -Charlie
                    Swing wild, brake later, don't apologize.
                    '89 324d, '76 02, '98 318ti, '03 Z4, '07 MCS, '07 F800s - Bonafide BMW elitist prick.
                    FYYFF
                    • Money$hit
                      • Mar 2008
                      • 1604
                      I clean my windows like weekly and they always end up filmy inside. Is this the cause?
                      • Money$hit
                        • Mar 2008
                        • 1604
                        -Charlie
                        Unsure of the Tstat. Like I said im the 2nd owner. I would assume its the stock unit.
                        • FredK
                          • 14761
                          yes.
                          • Money$hit
                            • Mar 2008
                            • 1604
                            So with the heater core issue, is it a matter of rebuilding, or replacing the unit?
                            • FredK
                              • 14761
                              Replace. You might be able to get a used one.
