a couple questions
  • jakeb
    • 1909
    a couple questions
    Does anyone have a drawing of the vacume lines under the intake. I have a few I am not sure where they go. The PO of my engine pulled the manifold off so I need to figure out where everything goes.
    Also there are 3 2 pin plugs under the manifold. Does anyone have a list of wire colors and where they all go?
    There is one coming off the harness that plugs into the HFM not sure what that is for.
    I have been searching but have not found what I am looking for.
    www.classicdaily.net
    1970 m42 swapped 2002
    1985 LS1/T56 Swapped e28 (557e)
    www.blunttech.com - For all your parts needs
    Follow me on Instagram for constant build updates @classicdaily
    https://www.facebook.com/ClassicDailyLLC
  • e30serg
    • Dec 2006
    • 562
    Engine? OBD1? OBD2?
    • jakeb
      • 1909
      e34 m50
      • jakeb
        • 1909
        I found this list....are these correct?
        oil pressure sensor BRN/GRN or BRN/GRY
        front coolant temperature sensor (ECU) BRN/RED BRN
        rear coolant temperature sensor (Gauge Sensor) BRN/YEL BRN/VIO
        cam position sensor YEL RED/WHT BRN/ORG
        VANOS solenoid RED/WHT GRN/BLU
        throttle position sensor (TPS) BRN BRN/BLK RED/YEL
        intake air temperature (IAT) sensor BRN GRY
        idle control valve (ICV) WHT/YEL RED/WHT WHT/GRN
        crank position sensor YEL BLK NCA
        Evaporative emissions valve BRN RED/WHT
        One connection I am finding is BLU/YEL and GREN/WHT
        Is there a pinout for an ecu somewhere. Does anyone have a ETM for a 93 e34 m50 they could send me...?
        • FredK
          • 14760
          You can find it at http://www.wedophones.com/BMWManualsLead.htm
          There is no pinout for the DME located in the ETM, but you can pretty much find the wire colors on the Fuel Injection section of the ETM.
          That list probably is the pinout that I created for the E36 325i harness when I had to wire up my engine.
          • Mike B.
            • Jan 2006
            • 987
            Freddy, there is a pin out for the DME in the ETM, just not for the x20. It doesn't tell you wire colors, just functions.
            • FredK
              • 14760
              Well I'll be! There IS a pin out for the DME (X6000)! :mrgreen:
              • jakeb
                • 1909
                Well I probed the DME connection to find out what this BLU/YEL and GREN/WHT connector is and there is no connection between it at the DME. Maybe it is something that goes to the x20. I will check there tomorrow.
                Any idea what this connection is for?
                Also I am still looking for a routing of all the vacuum lines.
                • Mike B.
                  • Jan 2006
                  • 987
                  Blue/Yellow may be the reverse switch on the transmission.
                  • jakeb
                    • 1909
                    checked the x20 and yes it is the backup light connection
