When I bought my S50, 5-lug cabrio, the PO said that the ABS pump ran all the time, so I should make sure to disconnect the battery or use a charger when the car sat for more than one night.
I'm not sure why the engine swap or E-36 5-lug would cause the ABS to run all the time; it could be some other current draw that the PO didn't know about.
So, I'm not sure if it's the ABS pump or not, but the battery definitely dies after the 2nd night. I'm not an electrical guru, so there's 2 options I'm considering:
1. http://www.amazon.com/Moroso-74103-B.../dp/B000COO1P4
2. Pull the relay for the ABS and see how the brakes do
Any thoughts on these or other options?
Thanks
Thanks
