Misfire + Overheating? Sounds definately like a head gasket issue. The leaky heater core could be a product of exhaust pressure leaking into the cooling system.
Today was a bad day.
I believe its a single cyl. Ive tried fixing it a few ways, switching things up (new valve cover gasket, new plugs, etc). Ill work on it and it will always run perfect with no missfire for about a mile or two, then it will revert back into its way.
"-Check for proper wp/them operation"
Are you talking about proper waterpump and thermostat? I think my next purchase is a new thermostat and some of the spark plug rubber boot things because a few are pretty cut up/gunked up w oil that was getting in there before I replaced the valve cover gasket.Comment
-yes I was, and yes you should replace those as well.1989 cirrisblau-metallic 325iComment
screw this replacing... bleed the coolant system. That IS is your problem. and its free!e30sport.net
'06 M3 Competition - 6-speed
'97 Range Rover VitesseComment
If you are using the m42 or e36 radiator with the built in tank then there is a little bleed screw at the top of the rad.
I am not sure the proper way on a m50 to bleed without that, as the e36 would have that radiator.
In the 2002 world people either lift the front of the car to get the bubble to come out the rad cap(cap off). You can also loosen the top rad hose and let it leak out there. use a little pic to pull the hose off the rad connection a little bit. Not actually take the hose off but just pull it up to let coolant/air escapewww.classicdaily.net
1970 m42 swapped 2002
1985 LS1/T56 Swapped e28 (557e)
www.blunttech.com - For all your parts needs
Follow me on Instagram for constant build updates @classicdaily
https://www.facebook.com/ClassicDailyLLCComment
what radiator did you use? You should have either a) used an m42 or e36 rad that had the bleeder on the radiator or b) drilled an tapped your thermostat housing. in this case unscrew your bleeder screw. On the e36 and m42 rads its the plastic screw on top.
if you did neither remove coolant resi cap and slightly pull back upper rad hose
start the car and keep the rpm right above idle and blast the heat in your car... full hot. Have extra coolant on hand! when the thermostat opens all the air will rush out of your radiator. ADD EXTRA COOLANT. Keep going until your coolant level settles and there are no more air bubble coming out anywhere. Remember keep the revs higher than idle and keep an eye on your coolant level and yoru engine temp.
for your misfire. If you want to do it cheap buy 1 extra coil and swap coils one by one until you find your misfire and it geos away. Or just replace all of them... its a good idea anyway if they are the originals anyway.e30sport.net
Thanks to Justin(GazellebeigeM3dildo), today I was able to get some of the issues sorted out.
- Fan clutch is toast as I kinda suspected
- Pressure test on coolant system revealed a small crack in the radiator
- Testing coils he pulled from his car revealed that one of the coils is definately bad
- Head gasket test revealed no issues with head gasket (thank jesus)
Again, Justin hooked me up with an extra coil and definately lent a helping hand to a retard like me. Definately a standup guy that I thank, and owe a couple cases of "Buusch" to.Comment
