m50 exhaust.... 2.25" or 2.5" single?
  • jakeb
    • 1909
    I am close to getting exhaust for my swap. It is going into a m42 car which by stock has 2.25" exhaust. Will the stock system (with a super turbo) choke a m50? or will it be enough for it. This would be with the stock cat and resonator. The exhaust is in good shape and it would be nice to just use it....
    Or should I go a little bigger.
    oh...btw I am running an ebay header off the m50tu.
    jake
    www.classicdaily.net
    1970 m42 swapped 2002
    1985 LS1/T56 Swapped e28 (557e)
    www.blunttech.com - For all your parts needs
    Follow me on Instagram for constant build updates @classicdaily
    https://www.facebook.com/ClassicDailyLLC
  • e30this
    • 3580
    on my m50 I ran a dodge magnum magnaflow converter right after my ebay headers. then I ran a single 2 1/2 all the way back into a dynomax super turbo.
    IMO I would never use that muffler on a m50 because it sounds like a rice burner or a crotch rocket.
    You should look into a flowmaster 40 series for that nice deep sound.
    if your worried about ground clearence then I would run dual 2 inch all the way back.
    shit even 1 7/8 will work.
