Last Saturday, I changed the oil and filter in my S50. The old oil looked good. I installed a Mahle filter with new o-rings and replaced the crush washer on the drain bolt. Added 5 quarts of Mobil 1 10W40.
Today, Monday morning, I added a can of fuel injector cleaner to an almost-empty gas tank and drove to work. Halfway there, the "engine oil" light came on. I pulled over and was horrified to find that the oil was 2 quarts low and emulsified; it looked like water had gotten into the oil. I bought 2 quarts of oil at a 7-11, put it in and drove to work (1 mile from there).
The engine did not overheat at any time.
When I get off work, I'll change the oil again and check the coolant level to see if I lost a substantial amount from the reservoir.
So what are the pain options - blown head gasket? cracked head? cracked block? And why?
