e34 m50 in 325es need wiring help!!!!
  • ///Motometrics
    • 17
    Need wiring diagram to make custom adpter for e34 m50 into an
    e30 325es thanx :up:
  • e30this
    • 3580
    search, theres already a thread with all the info you need.
    • ///Motometrics
      • 17
      yes there are tons for the is cars i need one for es cause mines not working right
      • e30this
        • 3580
        Then you did something wrong.
        I had an adapter plug from AKG and I used it on my 318 swap. then gave it to my buddy who used it on his 325e with m50 swap and it worked perfect.
        So go back and check your wiring.
        • brandon11130
          • Jan 2008
          • 635
          mike my car is a 88IS its the same from 88-91 are the same, 87 and back us a slightly different plug iirc
