318i basically the same as 325i?
  • Leeroy
    • Apr 2008
    • 587
    I was wondering if a 318 has the same body measurements and engine bay as a 325i? would body parts from a 325i fit on a 318? Thanks
    Transaction Feedback Thread:
    http://www.r3vlimited.com/board/showthread.php?t=150103
  • eko
    • Mar 2006
    • 372
    99% of parts are interchangable.
    94 316i Touring M52B28
    Made in Germany perfected in Britain!
    • SpecM
      • Oct 2005
      • 4531
      -pretty much the same car, as said, 99% of it is.
      1989 cirrisblau-metallic 325i
      • Leeroy
        • Apr 2008
        • 587
        Sweet thanks,
        Now if I swapped a M20 into a 318 would it be hard to change out the wiring harness? What else would I need to swap out Ecu or any other electronics?
        • Aptyp
          • 6584
          plug and play, you'll have to get tranny, driveshaft, engine and just slap it in.
          • Leeroy
            • Apr 2008
            • 587
            I dont have to worry about wiring harness? basically same electronics?
            • SpecM
              • Oct 2005
              • 4531
              -this is the wrong sub-forum for this!
              -and you would use the m20 harness and computer, the rest should match with some small adjustments
