well thinking i might swap an m50 i been doing some reading and i know there's lots to read and I'm probably jumping the gun of the questions but any way. I'm not positive on what m5* i would be swapping is it the same work to swap all m5*'s? or is there different things to do if its a 2.5 / 2.8 / 3.0 ect? i'm thinking it will be a 2.5 or 2.8. also will buy the wiring adapter, e28 motor mounts, e34 525i oil pan/pick up and dipstick. do i use the e36 rad? also do i need the e36 trans? or is mine ok? if i use e36 trans will my stock drive shaft work? and the brake booster whats my options for that? can i just move mine over a little? or what ones will work? fuel pump? what else am i missing? and any web sites for buying swap parts or good lists of parts for the swap would be a great help.
thanks
thanks
