318 vs 325 for an s50 swap
  • SpecM
    • Oct 2005
    • 4531
    Originally posted by raoke
    Only the is models have LSD right? Not the i models or the es?
    LSD was standard on the 325"is" and "es", and option on the i + e +318
    1989 cirrisblau-metallic 325i
    • 318isbmw
      • Nov 2005
      • 2841
      318is it was an option as well.
      • 1990m3
        • 1180
        true, my 318is had an open diff before I changed everything over
        • FredK
          • 14761
          As long as the axles are in good shape, you don't need to swap them. They bolt right up to a medium case diff. You do, however, will need to swap differential output flanges and the rear diff cover if the 3.25 LSD is from an E28/E24/E23.
          • m3_eater
            • 413
            Is it true that no 318i models came with check panels from the factory? If so, that means the PO installed mine and I never asked. My last E30 was a 325i, so I just assumed that all of them had check panels.
            E30 24V 6MT SOLD :( - look for it in sunny Miami :)
            • 318isbmw
              • Nov 2005
              • 2841
              Yes that is true...
              • 1990m3
                • 1180
                also true...I was able to use the 318is axles with my e30 m3 5-lug swap. I've also used diffs from mcoupe and e28 by swapping output flanges...takes about 1 minute to do that.
                • 91Saleen#15
                  • Mar 2006
                  • 230
                  Originally posted by jakeb
                  late 318 has less sound deading tar, none in the trunk. So it is a little lighter. Also no power sunroof, lighter. No check panel lights to look at after the swap.
                  Also no Cruise...but it is easy to add. Less of a OBC (easy to add, if you care about it)
                  The wiring is a little different for the 318. not a big deal tho. You can also use the 318 rad with the m50 for a cleaner engine bay.
                  I have a m50 swapped 318iS and am very happy with it.
                  I've been trying to figure out what the difference is in the wiring, but haven't found it anywhere. Can you point me to something?
                  Richard
                  • jakeb
                    • 1909
                    This might help. This is what I used. ABS goes to pin 3 on the x20.
                    Pulled from this post .
                    www.classicdaily.net
                    1970 m42 swapped 2002
                    1985 LS1/T56 Swapped e28 (557e)
                    www.blunttech.com - For all your parts needs
                    Follow me on Instagram for constant build updates @classicdaily
                    https://www.facebook.com/ClassicDailyLLC
                    • dpgrand
                      • 179
                      were sunroofs an option on a 1991 e30 318is? Or was it standard?
                      • Stu
                        • 4083
                        optional
                        • el_gringo
                          • Mar 2008
                          • 299
                          my 91 318is has a hand cranked sunroof, power windows, power mirrors, no trunk tar, open diff, 5 speed (not optional) coupe, and one big plus to starting with a 318is is the tranny mount.... i know for a s5x swap you need to make a new mount... not in the 318is!
                          • dpgrand
                            • 179
                            also - can these engine wiring harness adapters, such as the AKG one, be used with a 1991 318is?
                            • FredK
                              • 14761
                              ^ Yes
                              • el_gringo
                                • Mar 2008
                                • 299
                                i dont want to sound like a dick, but look at different threads... you will pick up on it.
