S50 - coolant drain on block?
  • funcrew
    • Jun 2007
    • 1223
    Does the S50 have a coolant drain on the block like an M20 does?
    "If the sky were to fall tomorrow, the tall would die first."
    -Dr. Paul Forrester
    Do I LOOK like I need a psychological evaluation???
  • matt
    • 3731
    Yes, it's even in the same place.
    • gregslow318i
      • Sep 2007
      • 1918
      and the same size
      looking for a e30m50 swap harness adapter pm me $150 shipped
      email nitroman12@gmail.com
      • ColdAccord
        • 5926
        lolz
        Originally posted by blunt
        • golde30
          • 11464
          i got a better question, where are you guys bleeding the cooling system when using m20(late) radiator w/ m/s50 motor? i been doing mine from the reservoir cap...
          IG: @Baye30
          • FredK
            • 14761
            Yep, I just leave the reservoir cap open, turn the car on, max heat max fan, rev it for a while until I see the level of the coolant rise (takes a couple of mins), bring the revs back down, then shut the car off. I find the late M20 expansion tank already does a decent job filling most of the system since it is up so high, in comparison to the M42's built-in reservoir.
            • el_gringo
              • Mar 2008
              • 299
              x2. the m42 one is a bitch...
