Need help diag minor issue S52 swap
  • stormspike
    • 401
    I have a small issue with the swap. She runs great, starts great, etc, but there is an issue when I start the car after it has sat for a while (cold-6+hrs).
    1. fires up with not issue and idles great.
    2. When I put the car in 1st and let up on clutch slowly, runs fine.
    3. Only issue is when I apply gas, wants to bog down. If I give it a couple of quick gas then it runs fine and goes.
    4. If I let it idle for a minute or so, no issues. Starts and runs great.
    5. After the few pumps with gas, she runs great all day.
    This seems to be only an issue when I start in the AM. Fires up quickly and runs great until I apply gas. After 2 rev ups, it seems to be fine. Is there a sensor that would cause this?
    thanks,
  • etxxz
    • Feb 2006
    • 2085
    too low rpm's maybe. vac leak. my car does the same under 700rpm. above that, there's no stopping it.
    No more e30s for me.
    88 black BMW OBDII 332is dedicated track [sold]
    88 BMW OBDII bronzit 332is [RIP 03/08]
    91 BMW 325i [sold]
    86 Corolla 'Ae86' HB 20v trd [sold]
    http://youtube.com/watch?v=pTj7Hn9v5Rs
    • loonibab325i
      • Dec 2005
      • 770
      also check and make sure your ecu is boltd up correct, mine would do a similar thing and loose ground everytime i'd turn or shift hard..
      s52 0-150mph & more http://www.youtube.com/loonibab325i
