i always see this clean beautiful black plastic that covers the harness .. what did you guys use? and from what car? :roll:
wiring cover.. can anyone tell me what you guys used
use search function and search for e30 m3 harness cover or go to realoem.com and look for it there under e30 m3 chassis.
edit...
http://www.realoem.com/bmw/showparts...51&fg=20&hl=42 -
best part of the whole swap. alot of people dont know it but the main relays even clip onto it.Comment
So you need these four?
21 TRIM PANEL WIRE HARNES ENGINE 1 51711380392 $20.31
22 COVERING WIRE HARNES ENGINE 1 51711380391 $18.19
23 SUPPORT WIRE HARNES ENGINE 1 51711380390 $22.32
24 INSERT WIRE HARNES ENGINE 1 51711380888 $5.93Mtech1 v8 build thread - https://www.r3vlimited.com/board/sho...d.php?t=413205
OEM v8 manual chip or dme - https://www.r3vlimited.com/board/sho....php?p=4938827Comment
This install was not totally P/P on my 89 E30
No screws required really. I mounted mine using 2 plastic nuts on existing studs both across the top 1L/1R but you have to drill new holes in the back over. If you want to mount the plastic holder for the C101 connector you will need longer screws if you left the insulation on the firewall. I used 2e 4mmx 15 mm screws.
Start installation by locating back plate using the studs for the C101 bracket.
A dremel tool is your friend GLComment
I had to cut some of the studs off my squirrel cage cover, and I was able to use some miscellaneous hardware to fasten the covers on. I think I used 2 of the existing studs and cut the rest off.Comment
no none of the existing studs really line up. 2 new holes. also shave off the male 'boss on the back side on pass side end so the plate will lay flat and as mentioned other studs can be cut off or bent out of the way.Comment
