Alirghty, on to my new problem..
Now that the car starts I tried to bleed the cooling system today. First thing I noticed is that the temp gauge is not working, second is that heater is blowing cold air, and third is that I cannot tell for sure if the tstat is opening.
Now I have searched and just want to confirm with the M5x/S5x veterans on what I need to fix this. Here is what I have gathered, if you can please confirm.
1. Swap E30 coolant temp sensor into the M50? (Which one blue or brown?)
2. The spider hose should be connected to the upper heater core hose and the hose coming from the cylinder head should be connected to the bottom heater core hose for the heat to work?
3. The incorrectly installed spider hose might explain why there is an air bubble in the head no allowing the tstat to open correctly?
