So , we know we have to source a e34 m50b25 oil pan for the e30 M50 swapp if you got a M3 engine like the one I have sitting in my garage (95 year model).
While checking in the ETK, came across two different part numbers for the oil pan of the e34 m50b25, one up to 02/94 date and the other from there and newer oil pans.
Waht would be the correct one?
Also, how about the oil pump? Both are the same? Do I need to pick up the e34 oil pump that comes with the oil pick up colector or can I use the stock M3 oil pump with a modify oil pick up colector since the M3 it's the only one that comes appart the oil pick colector vs the e34 m50b25 version that comes together with the oil pump?
Here are some shots of the ETK
CARTER DE ACEITE = OIL PAN
BOMBA DE ACEITE = OIL PUMP
Thanks!
Thanks!
