e30 m50 tranny swap question??
  • Jowey
    • May 2008
    • 25
    How good does the getrag 240 work on m50 engine?
    Also which driveshaft to use?
    What is the the best flywheel to run on this?
  • SpecM
    • Oct 2005
    • 4531
    yes
    e30 325i
    e30 325i
    1989 cirrisblau-metallic 325i
    • dpgrand
      • 179
      The getrag 240 tranny will word just fine for the m50 engine!
      • Jowey
        • May 2008
        • 25
        which cluts the 325 or 318i
        and which tranny arm and motor mout is best to use
        • SpecM
          • Oct 2005
          • 4531
          • dpgrand
            • 179
            tranny brace - stock e30
            motor mount - E28 535i or M5
            • e30this
              • 3580
              to run the 240 trans use a m20 single mass flywheel, m20 clutch, euro 323 to bearing.
              For the brace you can use the 240 brace with the stock mounts.
              • SpecM
                • Oct 2005
                • 4531
                y'all are no fun
                • e30love
                  • May 2007
                  • 831
                  i thought you had to use a e36 325i drive shaft for the 240
                  24v swapped
                  • asubimmer
                    • 6482
                    thats what I'm using
                    • 318isbmw
                      • Nov 2005
                      • 2841
                      Me too. The front part atleast, its stock 318is rear driveshaft.
                      This tranny swap isn't really covered in the comprehensive specM...
                      ASU started some really good threads when he was doing his swap, and there's a few threads that I started that info was in as well.
