building a 24v DOHC engine
  • Massive Lee
    • Sep 2006
    • 6785
    Originally posted by lifeiskaos
    care to elaborate?
    People who are serious about such project (and have the technical knowledge to achieve it) don't post questions as the ones you just asked. Lots of wishfull thinking and particularly no clear direction.
    Sorry for bringing the bad news. What's your background that makes you think you can build a 500hp motor with 10:1 pistons, with race cam and loppy idle, with MS but not on start-up? Why are you scared of engine management
    massivebrakes.com
    • dpgrand
      • 179
      i love these threads!
      • mentaleeill
        • 850
        i meant just to start with a m52, use its crank and get custom rods and pistons. want to keep the bore as small as possible to keep material between the cylinders on boosted engines for headgasket sealing. so look on bfc and there are plenty of people with their rod and piston specs posted.
        • lifeiskaos
          • 1709
          i am very serious about this project. do you think some people are born with such knowledge? im sorry for trying to learn? no clear direction, shall i quote myself?
          my background has been working with cars all my life, building several engines, tuning experience with megasquirt. i said i want lower than 10:1 comp pistons. i asked for specific advice, not your opinion. if you have nothing helpful to share, please gtfo
          hooray!
          • dpgrand
            • 179
            hooray!
            My sarcasm apparently was not noticed. +1 on bimmerforums though.
            • Kerrath
              • Jun 2008
              • 577
              You're cool.
              • SpecM
                • Oct 2005
                • 4531
                Epic thread!
                I say m50nv block, s52b32/m54b30 crank, and 84mm (85mm tops) pistons
                strong block, long stroke, and narrow bore for more sealing
                1989 cirrisblau-metallic 325i
                • lifeiskaos
                  • 1709
                  Originally posted by SpecM
                  Epic thread!
                  why is an m50nv block any stronger than a vanos m52 or an m52 block?
                  • kronus
                    • Apr 2008
                    • 13028
                    ^^ the cylinder walls are thicker and can take more pressure
                    cars beep boop
                    • Kerrath
                      • Jun 2008
                      • 577
                      Even after he bores them to 2.9L?
                      • lifeiskaos
                        • 1709
                        hmm. interesting. so, starting with an m50 block, what would i do for the cams/head?
                        • SpecM
                          • Oct 2005
                          • 4531
                          just use a s52 head
                          • lifeiskaos
                            • 1709
                            just use a s52 head
                            options are m50nv, m50 vanos, or m52 head. cams and valve will likely change so it doesnt matter a whole lot
                            • SpecM
                              • Oct 2005
                              • 4531
                              m52
                              same head as an s52, minus cams/springs/retainers
                              • lifeiskaos
                                • 1709
                                m52
                                sounds good. no one has mentioned rods. lets say im going to use an s50 crank. which rods should i use? pistons will probably be custom low comp 1mm overbore
