OBD1 Maf plug
  • mongule
    • Dec 2004
    • 177
    OBD1 Maf plug
    Anyone know where I can get the plug for the maf of an OBD1 harness?
    I'm making an adapter to go from OBD2 to OBD1 maf, I have the OBD2 part from an Old broken OBD2 MAF, I just need the plug/pigtail for the OBD1 MAF.
    87 OBDII 328is
  • dpgrand
    • 179
    cut it off at a salvage yard
    • matt
      • 3732
      Why are you doing this?
      The part number for the plug that connects to the OBDI MAF is 61 13 1 392 224. You will need pins (actually female sockets) to insert into it also. 61 13 1 376 202 x4.
      • mongule
        • Dec 2004
        • 177
        Because I have a free s50 MAf, and my OBD2 maf is busted,
        Thanks for the pin numbers.
        87 OBDII 328is
        • e30s52
          • Oct 2007
          • 5235
          you know turner makes an adapter for this right?
          www.gutenparts.com
          • mongule
            • Dec 2004
            • 177
            yep fully aware now.
            Anyways I allready made a makeshift adapter, I just wanted the plug to make it cleaner.
            I'll just get the adapter, its cheap.
            87 OBDII 328is
            • e30s52
              • Oct 2007
              • 5235
              yeah i think its 25 bucks or somthing and looks really clean.
              www.gutenparts.com
              • mongule
                • Dec 2004
                • 177
                So just to clarify this,
                Are OBD2 and OBD1 mafs interchangeable
                I mean besides the plugs physical difference.
                87 OBDII 328is
                • matt
                  • 3732
                  Nope.
                  • rThor432
                    • Feb 2007
                    • 3907
                    Originally posted by matt
                    Nope.
                    Haha.. I was thinking the same thing the entire time I was reading through this thread.
                    • mongule
                      • Dec 2004
                      • 177
                      Ok....
                      so is it the tuning that's different for the maf.
                      Why are 540 mafs used and "euro" mafs used interchangeably between OBD1 and OBD2
                      Any specifics? I know its Siemens vs Bosch but what exactly is different.
                      What will it affect. I put the one I had on hand and took it for one mild drive. And the car runs fine...idle is fine etc. Will it run lean/rich? Or will the computer simply ignore it. Unplugging it and and plugging definitely affects the idle.
                      87 OBDII 328is
                      • Uber E30
                        • 1409
                        They arent, the only 3.5 MAF i know of that works with an OBDII m/s5x is a Porsche 803.
                        -Alex
                        • mongule
                          • Dec 2004
                          • 177
                          Bimmerworld sells a plug for it so there must be an application.
                          In all honesty I'm just curious as I will get an OBD2 maf, since its like 30$ more then the adapter for a used one.
                          87 OBDII 328is
                          • Uber E30
                            • 1409
                            See the key word here is interchangeably. Buying an adapter or splicing wires is not interchangeable.
                            -Alex
                            • mongule
                              • Dec 2004
                              • 177
                              Well more specifically then is there a difference in the reading they put out or a difference in the the way the dme reads the signal that make them not possible to be used?
                              87 OBDII 328is
