Witch wiring harness
  • logger
    • Mar 2007
    • 385
    With a m52 swap ( into a 91 318is ) can I use a m50 wiring harness or do I have to use the m52 wiring harness ?
    sigpic I HATE SPEED BUMPS !!!!!
  • SpecM
    • Oct 2005
    • 4531
    Witch?
    Goblins, wizards and dragons too?
    1989 cirrisblau-metallic 325i
    • rThor432
      • Feb 2007
      • 3907
      Either one will work. Depends on whether you want to go OBD1 or stay OBD2.
      • logger
        • Mar 2007
        • 385
        So If I go OBD1 I can use the m50 wiring harness and ecu right ?
        • mongule
          • Dec 2004
          • 177
          If you go OBD1, you should use the m50 harness and Ecu,
          And if you go OBD2 you keep the m52 harness and ecu.
          87 OBDII 328is
          • dpgrand
            • 179
            you'll need more than the ecu to stay OBD2, unless you delete the EWS.
            • Mohammed_A
              • 344
              Sorry for the ignorance but does the obd1 have ews or is it only obd2
              • gobuffs
                • Dec 2004
                • 513
                Some OBDI engines have EWS (build date on or after 1/95 will have EWS).
                FYI, the S50 B32 is not OBDII.
                • Mohammed_A
                  • 344
                  how do i know if i have the s50 or s52?
                  • gobuffs
                    • Dec 2004
                    • 513
                    The S52 is a US only motor.
                    • Mohammed_A
                      • 344
                      in that case, mine is a s50b32.... thanks for clearing that up... what i do know that it does have ews
                      • gobuffs
                        • Dec 2004
                        • 513
                        Yes I told you you had a S50B32 in another thread. I would have assumed that you knew that all S50B32s were built after 1/95, therefore all S50B32s have EWS.
