so heres the story, i took the bolts off the crank pully to put the supercharger one on and left it like that. i couldnt get it off so i figured there was one more nut i was missing on the center. i went on a dyno and when it was redlined the pully came loose and put a nice mark on my rad, draining the entire thing. yes im an idiot, after that i couldnt even start the car. it cranks over a couple times than stops on a dime. i pulled out all the plugs, then it cranks over without stopping so i dont have an internal problem, it has to be electrical. the only thing that could have happened is the crankshaft sensor getting banged around by the pully. i removed the sensor and there is a dent at the bottom of it, but i dont remember if it was there before, could this be the problem?? any suggestions would help me out, id like to get it running before installing the blower.
problem...no start, need help
Tags: None
try getting a new crank sensor. when the pulley came off it might have damaged it. other then that i dont know. maybe your timing is way off but that wouldnt explain it just stop on a dime like that. -
i think ill make the 40 dollar investment, it really cant be anything else.
p.s. ill get some pics of the blower, i resprayed it, i couldnt stand the scratchs all over it. i found out my chip is for stage 2 with 30lb injectors and 9 psi pully!straight to stage 2!
nice. i cant wait to see a video of it. how much did you get the blower for again?Comment
true. still thats a good deal.Comment
