found a 2000 z3 m roadster engine/trans
  • flyboyx
    • 8371
    In my ventures, i just happened across a guy with a '00 m roadster wrecked/basically totaled. I am trying to figure out which version of the s50 that would have come with. wikipedia says it would be a s54b32. that would certainly be worthy of kicking my m42 to the curb. wikipedia also says the engine should have individual throttle bodies. when i looked under the hood, i don't think so, but it was dark and i really wasn't looking for that as i hadn't done any research to that point. so, my question is: which version am i looking at? not taking into account the acquisition cost of the engine/trans/ecu/wiring harness, about how much in dollars am i looking at in periferials to do the swap? I was just thinking that i also ought to have the differential as well, since i believe it will bolt in. what else would be an easy swap/upgrade from that car to an e30?
    peace
    brian
    Gigitty Gigitty!!!!
  • asubimmer
    • 6482
    the early ones came w/ the s52 and the late models came w/ the s54
    • flyboyx
      • 8371
      how do i tell the difference between an s50b32, and an s54b32? generally speaking, what will i need to replace to swap this engine into my e30? oilpan? radiator? motor mounts? drive shaft mod?
      Gigitty Gigitty!!!!
      • Jean
        • 18228
        everything that a typical 24v swap requires. read the long thread on here?
        • asubimmer
          • 6482
          well they look very different. like you said though the s54 has ITB's...
          S52
          S54
          • Danny
            • 14216
            2000 they switched to S54 IIRC
            • lifeiskaos
              • 1709
              s54 itb's work on s52's?
              • Dominic49
                • Feb 2007
                • 1373
                no
                • FredK
                  • 14763
                  They switched for the 2001 model year.
                  The differential will bolt in. You can use the rear trailing arms and brakes to convert to a 5-lug setup with large rear brakes, as long as you upgrade to the M3/Z3M brakes up front.
                  You can use the transmission (it's a ZF 320).
                  You can't use the Z3M driveshaft. It's too short. You need an E36 M3 or 328 driveshaft.
                  Otherwise it's just like a regular S/M5x swap if you have the S52. The US Z3 never came with an S50B32. That was only available overseas.
                  • jahnaboi
                    • Oct 2006
                    • 1742
                    ^ - yup. s50b32 = euro motor. Never offered in the States. The motor you are trying to differentiate is the s52b32.
                    SINdelle:E36 M3 5-Lug | 17x8 & 17x9 BBS RS | S52/ZF | 2.93LSD/3.5HFM/24lb Injectors/C&S Chip[B]SOLD[B]
                    • Mystikal
                      Wheel Fitment Expert
                      • 9602
                      Everything this guy said.
                      2000 = S52
                      Also, it has a 3.23LSD. That's useful. FWIW S54 ones have a 3.15.
                      • etxxz
                        • Feb 2006
                        • 2085
                        how much can you get the car for? you can get a full engine swap, 5-lug (unless suspension is wrecked) and a lot of money from parting out the rest. i'd do it if the price was right
                        No more e30s for me.
                        88 black BMW OBDII 332is dedicated track [sold]
                        88 BMW OBDII bronzit 332is [RIP 03/08]
                        91 BMW 325i [sold]
                        86 Corolla 'Ae86' HB 20v trd [sold]
                        http://youtube.com/watch?v=pTj7Hn9v5Rs
                        • flyboyx
                          • 8371
                          well, the car is pretty cheap. like-most of you would shit your pants-cheap. but it is apparently pretty trashed also. only has 47,000 miles, though. i am going to look at it in an hour or so. the pax side rear suspension is damaged fwiw. dont know how bad. in the photo he sent me, it looks like at least the trailing arm is bent. the guy is spanish, and a little hard to understand on the phone, but i think he said the power steering rack is damaged as well. knowing myself, i will probably decide i can't live without it when i see it. lucky for me, i have a back yard at a rent house with a big privacy fence that is filling up with parts cars pretty quickly. looks like i will have the choice of 3 transmissions. at this point i don't know which one would be best. my car has a m42/5spd. i have a parts car m20/5spd. this apparently has the 6 speed zf. without knowing anything about it, i would be inclined toward the zf. does anone have any thoughts?
                          Gigitty Gigitty!!!!
                          • rThor432
                            • Feb 2007
                            • 3907
                            Dont worry about the bent trailing arm. You can still use the brakes from both sides and at least the hub from the side that isnt damaged. New hubs arent terribly expensive. The M coupe had top of the line stuff, dont pass it up!
                            • Mystikal
                              • 9602
                              No [E36-based] M Roadster/Coupe ever had a 6-speed from the factory.
