Will the throtle cable work off my 318is for m52 swap. Or do I have to get a e34 m50 ?
throtle cable
The e34 one is very simple not to much slack to it. All you have to do is adjust it alittle.Comment
Question: How do I dislodge the part of the throttle cable that is stuck to the firewall... I have no clue as to how to take it out?
Inside the cabin: Should I turn the plastic bracket and push out? Or what? I'm getting pwned. LOL.
SINdelle:E36 M3 5-Lug | 17x8 & 17x9 BBS RS | S52/ZF | 2.93LSD/3.5HFM/24lb Injectors/C&S Chip[B]SOLD[B]Comment
Its cliped in. look at realoem.comComment
its clipped, so you have to get inside and you'll see from the inside how you have to push I believe top and bottom to make it work. That being said, I pushed one and then forced it out breaking the other. Wasn't gonna use it again so said screw it.Comment
