which e30 m50 adapter should i buy? treehouse racing adapter costs 400 dollars! cant afford that. ive seen another for 200. does it matter? should i just do it myself?
which e30 m50 adapter to buy?
DIY Adapter. Comes with a free wire stripper and soldering iron and assorted collection of heat shrink tubing. -
I don't think its an electrical problem. Its either a faulty dme/cps/or mixed up fuel lines. But if I have spark doesn't that rule out the wiring and dme?
SINdelle:E36 M3 5-Lug | 17x8 & 17x9 BBS RS | S52/ZF | 2.93LSD/3.5HFM/24lb Injectors/C&S Chip[B]SOLD[B]Comment
Not too hard when you look at it like roads, each wire is a road. All you gotta do is get the traffic from one city to travel the correct road to end up in the right town next door.Comment
It only took me 45mins. The wiring diagram I got had the pin#'s. You can see the numbers on the plugs, not hard at allSold-87 325
BBS RK Wheels
H&R Cup Kit
E30 ///M3 Light up knob
Clutch Stop
///M Roadster FloorMats
Jim C Chip
91 318is
M50 Swap
Headers
UUC Underdrive pulleys
K&N 3in Cone
Jim C Chip
Soon H&R Coilovers
BBS RSComment
You will hear a battle from both sides, but from my experience, I have never seen a properly soldered, and heat shrinked connection break or seperate due to vibrations. Plus, butt connectors uncovered are a nasty place to get internal wire corrosion.Comment
