entire m50 swap must go
  • bimmerboy570
    • Mar 2007
    • 63
    i have the entire swap from an e34 non vanos. round harness already temporarily wired i have a manuel tranny swap no driveshaft. 2500
    with steering swap 3000 nepa
    i do not want to part must go ASAP
  • jahnaboi
    • Oct 2006
    • 1742
    Very poor selling skills and for 3k people could get an s50/s52. Sorry but better luck next time.
    SINdelle:E36 M3 5-Lug | 17x8 & 17x9 BBS RS | S52/ZF | 2.93LSD/3.5HFM/24lb Injectors/C&S Chip[B]SOLD[B]
    • bimmerboy570
      • Mar 2007
      • 63
      its not an engine only it is everything all together to put the entire swap into a car from the transmission to the radiator.
      • e30s52
        • Oct 2007
        • 5235
        3000 for a non-vanos motor isnt a good deal. You can find alot of nv motors for 800 with a tranny.
        www.gutenparts.com
        • mbonder
          • 2255
          I paid $1500 for everything...that was a deal, but I'd figure this is more in the range of $1800-2000.
          • bimmerboy570
            • Mar 2007
            • 63
            I only wanted 500 with the oilpan and dipstick harness as taken from car minus the ac pump.
            92 full engine with harness intake ect. 141k
            Ecu
            2 trannys a 260 and the stock e34 trans.
            M50 flywheel
            Flywheel e36
            Flywheel e36
            shift fork
            Clutch m20
            peddle assembly
            master/slave cylinders clutch
            AKG e32 hd trans mounts with cups
            tranny seal kit for the 260
            manuel cross member
            shift linkage
            shift rod
            thermostat s52
            gaskets for housing
            Hoses
            radiator
            reservoir
            new water pump
            belt
            ps pump
            E36 rack
            ps hoses and res.
            throttle cable
            m3 arms
            e34 arms
            engine mounts
            ix booster
            Headers
            • e30this
              • 3580
              So your saying you want 500 for a complete NV m50 with all accesories, wiring harness, ecu, oil pan etc?
              • bimmerboy570
                • Mar 2007
                • 63
                I would really like to sell all of the parts together. i dont have time to part it out. make a reasonable offer and i will consider it.
                • e30this
                  • 3580
                  none of your thread makes any sense. none of it is clear.
                  You need to sit down and think of how to put it in words so everyone can understand what your saying.
                  • bimmerboy570
                    • Mar 2007
                    • 63
                    I will not part this out, i do not have the time. I will consider offers.
                    • blunttech
                      • 12850
                      ill give you 500 for the whole thing and ill pay shipping
                      sales@blunttech.com
                      www.blunttech.com
                      Like us on Facebook
                      • bimmerboy570
                        • Mar 2007
                        • 63
                        If i decide to split everything up then i will contact you.
