On my 88 325is S52 with Getrag 250 swap I originally installed the shift carrier (part that holds the shift lever) from the old trans. This carrier placed the shifter about 2 inches too far forward.
SO I went about looking for the best solution to put the shifter back in the middle of the hole in the transmission tunnel without spending a fortune on trial and error.
Looking at a couple of carriers I had I noticed they had a a part number as well as an alpha numeric designation on them that read C=xxx. I wondered what that was, so I measured the center to center distance from the shift hole to the center of the carrier where it attaches to the transmission. Turns out that is what the number on the carrier means.
For example my E30 325is carrier has C=244, so it has a center to center span of 244mm or 9.6".
I have one that has a center to center of 325mm, it is from an E30 318 and is too long to work with the 250 Getrag.
I ordered the carrier for an E36 325is and it has a C=257.5 and moved the shifter back about 3/4", not as far I'd like but good enough for now. If I could find one about 280mm that would put the shifter in the middle of the trans hole.
It might be helpful for future swaps to compile a list of the carriers and the lengths...
