Nice thanks for the pictures, everyone made it sound like they clipped on or you could make the factory one work somehow.
E36 Radiator in an E30
If you would gave newer e30 those 318is plastic supports will just clip on and after that the e36 radiator fit like from factory. But your older e30 is missing those metal brackets.Comment
So this brings me to the question of is there a no weld solution for getting the M5x into an early model E30? I'm thinking of buying the newer radiator and just seeing how it looks in there, maybe I could make something to hold the bottom in place.
I have a welder, but I didn't realize that this had to be done and the engine is in now :(Comment
I welded in the late model brackets as well. The plastic "cups" are what clips in. The early model lower mount will support the bottom of the late model radiator but using the late model upper mount lets the radiator slide side to side. The early model upper mount is what keep the radiator in place side to side but the late model radiators don't have the mounting "ears" like the early model radiators did.So this brings me to the question of is there a no weld solution for getting the M5x into an early model E30? I'm thinking of buying the newer radiator and just seeing how it looks in there, maybe I could make something to hold the bottom in place.
